Usually this will write to you epicor905.server.log and give you more
information on the error.
Of tomdomurat
Sent: Thursday, October 25, 2012 2:18 AM
Subject: [Vantage] 4GL Stop error on UD data entry form
(In 700C)
I added the Epicor.Mfg.UI.UD01Entry.dll to a Menu item under "Program"
within Menu Maintenance.
I am able to pull this form up with the 5 Key Fields and 1 Character
field. When I click "New" record and try to add something and then try
to "Save", it immediately throws me a 4GL Stop error.
What I am missing here? This form has not been modified at all?
Error Detail
4GL STOP condition: The Server application has returned an error. (7243)
(7241)
Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID,
String procedureName, ParameterSet parms, Boolean persistent, Boolean
internal_Renamed, Int64 procId, MetaSchema localSchema, Int32
stateModel)
at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String
requestID, String fullProcedureName, ParameterSet inparams, Object
procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String
requestID, String procedureName, ParameterSet parms, MetaSchema schema)
at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String
at
Epicor.Mfg.Core.CallContext.CallContextPersistentProc.runProcedure(Strin
g procedureName, ParameterSet parameters, MetaSchema metaSchema)
at Epicor.Mfg.Core.CallContext.ProxyHelper.CallMethod(String methodName,
ParameterSet parameters, MetaSchema metaSchema, BLConnectionPool
connPool, Session connection, PersistentProc persistProc,
CallContextDataSet callContextDataSet)
at Epicor.Mfg.Proxy.UD01Impl.Update(UD01DataSet ds)
at Epicor.Mfg.UI.Adapters.UD01Adapter.Update()
at Epicor.Mfg.UI.App.UD01Entry.Transaction.AdapterUpdate()
at Epicor.Mfg.Shared.UDSupport.UDSingleViewTransaction.Update()
Of tomdomurat
(In 700C)
Error Detail
(7241)
Stack Trace
stateModel)
at
