4GL query from JobHead BPM
Only workaround I see is to write an external .p file, then create a 4GL action that forwards to it.
Hello All,
I am trying to run a query from the JobEntry.Update Object/Method on
a
Preprocessing BPM trigger. I am using the "design query is less
than" approach for the condition. Here is my query:
For each ttJobHead where ( ttJobHead.RowMod = 'A' or ttJobHead.RowMod
= 'U' ) no-lock.
Find PartRev WHERE PartRev.PartNum = ttJobHead.PartNum AND
PartRev.RevisionNum = ttJobHead.RevisionNum.
End
The query checks out OK in the Method Directives tool but when I run
it I get the following error:
Exception caught in: Epicor.Mfg.BO.JobEntry
Error Detail
Message: The field ttJobHead.AnalysisCdDescription does not have a
valid data type.
Type: Error
Program: bo/DynamicQuery.p
Method: buildTempTable
Table: SelectedField
Row:
Field:
Stack Trace
at Epicor.Mfg.Proxy.JobEntryImpl.Update(JobEntryDataSet ds)
at Epicor.Mfg.UI.Adapters.JobEntryAdapter.Update()
at Epicor.Mfg.UI.App.JobEntry.Transaction.Update()
Can anyone point me in the right direction?
What I am trying to accomplish is to read the part rev table for the
related part number and check off a VB field in JobHead to reference
on the traveler.
Ross
Hello Mark:
I would like to make a couple of suggestions:
- Do not use no-lock if you plan on updating the ttjobhead record
- Always use a no-error at the end of a find statement and then use
if available for additional processing
- Always use the company field in a find statement for integrity and
speed
- Make sure code is continuous - the normal Progress structure has
end statements on its own line
For each ttjobhead where ttjobhead.rowmod = "A" or ttjobhead.rowmod = "u",
first parrev where partrev.company = ttjobhead.company and
partrev.revisionnum = ttjobread.partnum and partrev.partrev =
ttjobhead.revisionnum.
Add logic inside.
End.
Carl Peterson
Ross Hughes
Sent: Friday, December 26, 2008 3:44 PM
Subject: [Vantage] 4GL query from JobHead BPM
Hello All,
a
= 'U' ). Find PartRev WHERE PartRev.PartNum = ttJobHead.PartNum AND
PartRev.RevisionNum = ttJobHead.RevisionNum no-error. If available partrev
then do: add logic end.
End
Error Detail
valid data type.
Type: Error
Row:
Field:
Stack Trace
on the traveler.
Ross
Thank you much for the suggestions, Carl.
I updated the code to the following and am still getting the same
error.
for each ttJobHead where
ttJobHead.RowMod = 'A' or ttJobHead.RowMod = 'U' ,
First PartRev WHERE partrev.Company = ttJobHead.Company AND
End.
I tried it as a PRE and a POST but get the same results.
Ross
--- In vantage@yahoogroups.com, "Carl Peterson" <cpeterson@...> wrote:
> Hello Mark:
record
then use
integrity and
> speed
structure has
= "u",
> Add logic inside.
> End.
> Carl Peterson
Behalf Of
> Ross Hughes
> Hello All,
on
> a
ttJobHead.RowMod
partrev
> End
run
> Error Detail
> valid data type.
> Type: Error
> Row:
> Field:
> Stack Trace
the
reference
> on the traveler.
> Thanks,
> Ross
error.
End.
Ross
> Hello Mark:
record
then use
integrity and
> speed
structure has
= "u",
> Add logic inside.
> End.
> Carl Peterson
Behalf Of
> Ross Hughes
> Hello All,
on
> a
ttJobHead.RowMod
partrev
> End
run
> Error Detail
> valid data type.
> Type: Error
> Row:
> Field:
> Stack Trace
the
reference
> on the traveler.
> Thanks,
> Ross
Just a WAG but the error message would seem to indicate a problem
with the table : field structure
what version of Vantage are you using and what db SQL or Progress?
> error.
> End.
> Thanks,
> Ross
> --- In vantage@yahoogroups.com, "Carl Peterson" <cpeterson@> wrote:
> > Hello Mark:
> record
> then use
> integrity and
> > speed
> structure has
ttjobhead.rowmod
> = "u",
> > Add logic inside.
> > End.
> > Carl Peterson
> Behalf Of
> > Ross Hughes
> > Hello All,
> on
> > a
> ttJobHead.RowMod
AND
available
> partrev
> > End
> run
> > Error Detail
a
> > valid data type.
> > Type: Error
> > Row:
> > Field:
> > Stack Trace
> the
> reference
> > on the traveler.
> > Thanks,
> > Ross
Progress and 8.03.407.
bw2868bond
Sent: Friday, December 26, 2008 6:29 PM
Subject: [Vantage] Re: 4GL query from JobHead BPM
> error.
> End.
> Thanks,
> Ross
> > Hello Mark:
> record
> then use
> integrity and
> > speed
> structure has
ttjobhead.rowmod
> = "u",
> > Add logic inside.
> > End.
> > Carl Peterson
> Behalf Of
> > Ross Hughes
> > Hello All,
> on
> > a
> ttJobHead.RowMod
AND
available
> partrev
> > End
> run
> > Error Detail
a
> > valid data type.
> > Type: Error
> > Row:
> > Field:
> > Stack Trace
> the
> reference
> > on the traveler.
> > Thanks,
> > Ross
Just tried a simple BPM to show message on Update method - I received
same error. My suggestion would be to contact support. I beleive the
BO is flawed.
Good Luck.
-bw
Behalf Of
> bw2868bond
> > error.
> > End.
> > Thanks,
> > Ross
wrote:
> > > Hello Mark:
ttjobhead
> > record
and
> > then use
> > integrity and
> > > speed
> > structure has
> ttjobhead.rowmod
> > = "u",
> > > Add logic inside.
> > > End.
> > > Carl Peterson
On
> > Behalf Of
> > > Ross Hughes
> > > Hello All,
Object/Method
> > on
> > > a
> > ttJobHead.RowMod
> AND
> available
> > partrev
> > > End
I
> > run
> > > Error Detail
have
> a
> > > valid data type.
> > > Type: Error
> > > Row:
> > > Field:
> > > Stack Trace
for
> > the
> > reference
> > > on the traveler.
> > > Thanks,
> > > Ross
must have
Builder and
Thanks a lot for trying this.
I will contact support on Monday morning.
Ross
On Dec 27, 2008, at 6:45 AM, "bw2868bond" <bwalker@...>
> BO is flawed.
> Good Luck.
> -bw
> Behalf Of
>> bw2868bond
>>> error.
>>> End.
>>> Thanks,
>>> Ross
> wrote:
>>>> Hello Mark:
> ttjobhead
>>> record
> and
>>> then use
>>> integrity and
>>>> speed
>>> structure has
>> ttjobhead.rowmod
>>> = "u",
>>>> Add logic inside.
>>>> End.
>>>> Carl Peterson
> On
>>> Behalf Of
>>>> Ross Hughes
>>>> Hello All,
> Object/Method
>>> on
>>>> a
>>> ttJobHead.RowMod
>> AND
>> available
>>> partrev
>>>> End
> I
>>> run
>>>> Error Detail
> have
>> a
>>>> valid data type.
>>>> Type: Error
>>>> Row:
>>>> Field:
>>>> Stack Trace
> for
>>> the
>>> reference
>>>> on the traveler.
>>>> Thanks,
>>>> Ross
> must have
> Builder and
> must have already linked your email address to a yahoo id to enable
> access. )
> Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo
> ! Groups Links
Why ttJobHead table and not just JobHead. Is that a BPM thing?
Bob
> Ross
received
the
> > BO is flawed.
> > Good Luck.
> > -bw
> > Behalf Of
> >> bw2868bond
Progress?
same
> >>> error.
> >>> End.
> >>> Thanks,
> >>> Ross
> > wrote:
> >>>> Hello Mark:
> > ttjobhead
> >>> record
> > and
> >>> then use
> >>> integrity and
> >>>> speed
> >>> structure has
> >> ttjobhead.rowmod
> >>> = "u",
> >>>> Add logic inside.
> >>>> End.
> >>>> Carl Peterson
> > On
> >>> Behalf Of
> >>>> Ross Hughes
> >>>> Hello All,
> > Object/Method
> >>> on
> >>>> a
> >>> ttJobHead.RowMod
> >> AND
> >> available
> >>> partrev
> >>>> End
> > I
> >>> run
> >>>> Error Detail
> > have
> >> a
> >>>> valid data type.
> >>>> Type: Error
> >>>> Row:
> >>>> Field:
> >>>> Stack Trace
> > for
> >>> the
> >>> reference
> >>>> on the traveler.
> >>>> Thanks,
> >>>> Ross
> > must have
access. )
> > Builder and
You
enable
> > access. )
> > ! Groups Links
tt* tables are interim tables BPM often uses..
I did try talking straight to the live table but didn't have success.
Of course, I may have done that incorrectly. I basically mirrored my
query with live tables. Different error.
Ross
> Bob
>> Ross
> received
> the
>>> BO is flawed.
>>> Good Luck.
>>> -bw
>>> Behalf Of
>>>> bw2868bond
> Progress?
> same
>>>>> error.
>>>>> End.
>>>>> Thanks,
>>>>> Ross
>>> wrote:
>>>>>> Hello Mark:
>>> ttjobhead
>>>>> record
>>> and
>>>>> then use
>>>>> integrity and
>>>>>> speed
>>>>> structure has
>>>> ttjobhead.rowmod
>>>>> = "u",
>>>>>> Add logic inside.
>>>>>> End.
>>>>>> Carl Peterson
>>> On
>>>>> Behalf Of
>>>>>> Ross Hughes
>>>>>> Hello All,
>>> Object/Method
>>>>> on
>>>>>> a
>>>>> ttJobHead.RowMod
>>>> AND
>>>> available
>>>>> partrev
>>>>>> End
>>> I
>>>>> run
>>>>>> Error Detail
>>> have
>>>> a
>>>>>> valid data type.
>>>>>> Type: Error
>>>>>> Row:
>>>>>> Field:
>>>>>> Stack Trace
>>> for
>>>>> the
>>>>> reference
>>>>>> on the traveler.
>>>>>> Thanks,
>>>>>> Ross
>>> must have
> access. )
>>> Builder and
> You
> enable
>>> access. )
>>> ! Groups Links
> access. )
> ! Groups Links
I know this is a somewhat dated thread but we've run into this AnalysisCdDescription error on 2 different BPM's (most others work just fine). Has anyone else had any success getting around this? Figured I'd check in here first before contacting support. We're on SQL w/ 8.03.408b.
Eric
> Ross
> > BO is flawed.
> > Good Luck.
> > -bw
> > Behalf Of
> >> bw2868bond
> >>> error.
> >>> End.
> >>> Thanks,
> >>> Ross
> > wrote:
> >>>> Hello Mark:
> > ttjobhead
> >>> record
> > and
> >>> then use
> >>> integrity and
> >>>> speed
> >>> structure has
> >> ttjobhead.rowmod
> >>> = "u",
> >>>> Add logic inside.
> >>>> End.
> >>>> Carl Peterson
> > On
> >>> Behalf Of
> >>>> Ross Hughes
> >>>> Hello All,
> > Object/Method
> >>> on
> >>>> a
> >>> ttJobHead.RowMod
> >> AND
> >> available
> >>> partrev
> >>>> End
> > I
> >>> run
> >>>> Error Detail
> > have
> >> a
> >>>> valid data type.
> >>>> Type: Error
> >>>> Row:
> >>>> Field:
> >>>> Stack Trace
> > for
> >>> the
> >>> reference
> >>>> on the traveler.
> >>>> Thanks,
> >>>> Ross
> > must have
> > Builder and
> > access. )
> > ! Groups Links
You will have to do it in straight 4GL code as an action.
What are you trying to do?
Ross
On Dec 17, 2009, at 5:36 PM, "precisionwirecomponents" <eackerson@...
> SQL w/ 8.03.408b.
> Eric
>> Ross
>>> received
>>> BO is flawed.
>>> Good Luck.
>>> -bw
>>> Behalf Of
>>>> bw2868bond
>>>>> error.
>>>>> End.
>>>>> Thanks,
>>>>> Ross
>>> wrote:
>>>>>> Hello Mark:
>>> ttjobhead
>>>>> record
>>> and
>>>>> then use
>>>>> integrity and
>>>>>> speed
>>>>> structure has
>>>> ttjobhead.rowmod
>>>>> = "u",
>>>>>> Add logic inside.
>>>>>> End.
>>>>>> Carl Peterson
>>> On
>>>>> Behalf Of
>>>>>> Ross Hughes
>>>>>> Hello All,
>>> Object/Method
>>>>> on
>>>>>> a
>>>>> ttJobHead.RowMod
>>>> AND
>>>> available
>>>>> partrev
>>>>>> End
>>> I
>>>>> run
>>>>>> Error Detail
>>> have
>>>> a
>>>>>> valid data type.
>>>>>> Type: Error
>>>>>> Row:
>>>>>> Field:
>>>>>> Stack Trace
>>> for
>>>>> the
>>>>> reference
>>>>>> on the traveler.
>>>>>> Thanks,
>>>>>> Ross
>>> must have
>>> Builder and
>>> access. )
>>> ! Groups Links
> access. )
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo!
> Groups Links
I am having the same problem with this error. has anyone found anything new about it or how to get around it?
thanks
> Ross
> > SQL w/ 8.03.408b.
> > Eric
> >> Ross
> >> On Dec 27, 2008, at 6:45 AM, "bw2868bond" <bwalker@>
> >>> received
> >>> BO is flawed.
> >>> Good Luck.
> >>> -bw
> >>> Behalf Of
> >>>> bw2868bond
> >>>>> error.
> >>>>> End.
> >>>>> Thanks,
> >>>>> Ross
> >>> wrote:
> >>>>>> Hello Mark:
> >>> ttjobhead
> >>>>> record
> >>> and
> >>>>> then use
> >>>>> integrity and
> >>>>>> speed
> >>>>> structure has
> >>>> ttjobhead.rowmod
> >>>>> = "u",
> >>>>>> Add logic inside.
> >>>>>> End.
> >>>>>> Carl Peterson
> >>> On
> >>>>> Behalf Of
> >>>>>> Ross Hughes
> >>>>>> Hello All,
> >>> Object/Method
> >>>>> on
> >>>>>> a
> >>>>> ttJobHead.RowMod
> >>>> AND
> >>>> available
> >>>>> partrev
> >>>>>> End
> >>> I
> >>>>> run
> >>>>>> Error Detail
> >>> have
> >>>> a
> >>>>>> valid data type.
> >>>>>> Type: Error
> >>>>>> Row:
> >>>>>> Field:
> >>>>>> Stack Trace
> >>> for
> >>>>> the
> >>>>> reference
> >>>>>> on the traveler.
> >>>>>> Thanks,
> >>>>>> Ross
> >>> must have
> >>> Builder and
> >>> access. )
> >>> ! Groups Links
> > access. )
> > Groups Links
