When running .809c on SQL we had a bug that would cause the 4GL stop error.
The bug was in the sales order search dialogue box - if alpha data was entered in the search field it would crash the system.
Epicor issued a hot fix for it but I never saw any public info about the bug - I found out from a larger organization that is kind enough to help us out.
We recently moved to 810c and do not have the problem but I can't say which patch resolved it.
While I'm here will mention that 810c seems to have a problem with miscellaneous charges to jobs - worked fine in .809c but as soon as we went to 810c it began to double the cost in the total on the production detail report.
David J. Murphy
Information Systems Manager
A&A Machine & Fabrication, LLC
Elevating the Art of precision machining
and fabrication from concept to completion
Voice (409) 938-4274
Fax (409) 938-3925
www.aagroup.com
David J. Murphy
Fax (409) 938-3925
www.aagroup.com
