4GL Baby steps
Thanks Thaddeus, Jim and William.
I installed my shortcut on six other workstations successfully. On the one
that failed I uninstalled progress client 9.1a and reinstalled it. This
solved the problem. I have succesfully written and deployed my first 4GL
program. I want to thank everyone who contributed to my education, THANKS!!
Mark Dupuis
I have taken the 4GL plunge. I am starting slowly by playing
with existing procedures using the procedure editor (prowin32). I
have created frames and widgets with functioning code. Using f2 to
run the procedure code works fine. Now I want to run the code from
my desktop or from within Vantage.
From the desktop I edited a .vtg icon (I saw this in a string a few
weeks ago) and changed the startup procedure to point to my procedure
(test.p). This starts the procedure ok but after I close the
procedure I get a progress login screen and then an instance of the
procedure editor with a file -untitled that opens. I assume it is
because the vtg file uses prowin32 as the executable. Is there a way
to run a 4GL procedure without using prowin32? Is there a way to
close the editor when the procedure is closed? I have the same
problem when I create a short cut with this line (also got this from
the group)
N:\progress\bin\prowin32.exe -db n:\vantage\db\vantage.db -N TCP -S
servicename -H servername -p n:\vantage\test.p
Ok all you 4GL'ers what am I missing? If the answer is lengthy
you
can reach me off the group but I would hope there are others on line
who might be interested. And THANKS to whoever posted the vtg info
and the shortcut info.
BTW: I do not have AppBuilder.
Mark Dupuis
dupuism@...
You need to add the QUIT command after the procedue ends.
Mark Charamut
President
Caesar Development Services, LLC
mcharamut@...
www.caesardev.com
(860) 667-4774 x20
> -----Original Message-----
> From: dupuismd [mailto:dupuism@...]
> Sent: Thursday, January 10, 2002 11:03 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] 4GL Baby steps
> the group)
> you
> Mark Dupuis
> dupuism@...
> ------------------------ Yahoo! Groups Sponsor
> Tiny Wireless Camera under $80!
> Order Now! FREE VCR Commander!
> Click Here - Only 1 Day Left!
> http://us.click.yahoo.com/WoOlbB/7.PDAA/ySSFAA/PhFolB/TM
> Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> You must have already linked your email address to a yahoo id
> to enable access. )
> Builder and Crystal Reports and other 'goodies', please goto:
> (3) To view links to Vendors that provide Vantage services
> goto: http://groups.yahoo.com/group/vantage/links
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
No $#!t. For 2 days I have been determined to work this one out. I just
wouldn't QUIT! Ha Ha.
Mark Thanks for the tip.
Mark Dupuis
dupuism@...
Sent: Friday, January 11, 2002 11:12 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] 4GL Baby steps
Mark Charamut
President
mcharamut@...
www.caesardev.com
(860) 667-4774 x20
> the group)
> you
> Mark Dupuis
> dupuism@...
> to enable access. )
alternately to creating a .vtg file, you can create a windows shortcut to
prowin32.exe with a target similar the following:
V:\DLCSRV\bin\prowin32.exe -db V:\apps\vantage\db\dcdv7.db -N TCP -S
vntgserv -H SERVERNAME -p X:\anypath\ProgramName.p
Case sensitivity matters with the commandline switches.
this will bypass the vantage.exe file, so the splash screen does not
display, and the program begins execution in a shorter amount of time.
HTH,
Thaddeus
Sent: Thursday, January 10, 2002 8:29 AM
Mark Dupuis
dupuism@...
Mark Charamut
President
mcharamut@...
www.caesardev.com
(860) 667-4774 x20
> the group)
> you
> Mark Dupuis
> dupuism@...
> to enable access. )
Since there've been numerous discussions about moving data around in
Vbforms, is there a practical way to copy the hire date from PREmpMas table
to the EmpBasic table when a new employee is entered, or is this a custom
programming situation?
Shirley H. Graver
(End User)
Systems Administrator
Rubber Associates Inc.
To make life easier I would create a .pf file and use the following:
V:\DLCSRV\bin\prowin32.exe -pf V:\Vantage\Path\file.pf
My .pf file would Look something like:
-db V:\apps\vantage\db\dcdv7.db -N TCP -S vntgserv -H SERVERNAME -p X:\anypath\ProgramName.p
Now you can update the .pf file when you change Servers or Versions etc. and you wouldn't have to go to each desktop to change the shortcuts, unless the drive mappings or
the path to the .pf file changes.
Jim
> HTH,
> Thaddeus
> From: Mark Dupuis [mailto:dupuism@...]
> Mark Dupuis
> dupuism@...
> From: Mark Charamut [mailto:mrprogress@...]
> Mark Charamut
> President
> mcharamut@...
> www.caesardev.com
> (860) 667-4774 x20
> > the group)
> > you
> > Mark Dupuis
> > dupuism@...
Interesting solution, Jim. Thanks for sharing it. I can see where if the number of Programs you were running this way increased much, this could simplify the installation process on PC's. Just the kind of information that makes this list so educational and helpful.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Friday, January 11, 2002 9:01 AM
Subject: Re: [Vantage] 4GL Baby steps
Jim
> HTH,
> Thaddeus
> Mark Dupuis
> dupuism@...
> Mark Charamut
> President
> mcharamut@...
> www.caesardev.com
> (860) 667-4774 x20
> > the group)
> > you
> > Mark Dupuis
> > dupuism@...
ADVERTISEMENT
Great idea Jim, and nows the time for me to do this, before I create forty
shortcuts.
Thanks!
Mark Dupuis
drive mappings or
Jim
> HTH,
> Thaddeus
> Mark Dupuis
> dupuism@...
> Mark Charamut
> President
> mcharamut@...
> www.caesardev.com
> (860) 667-4774 x20
> > the group)
> > you
> > Mark Dupuis
> > dupuism@...
Hello 4GL'ers
I have completed my first program. It's rather simple, it gets a date from
a user along with number of days and then runs a report using this info in
the filter. I have a desktop shortcut (Thanks Thaddeus) and a .pf file with
the database info. (Thanks Jim) When the program runs it creates a .csv file
on my desktop as planned. When the user clicks exit the program closes
along with the procedure editor. (Thanks Mark)
Now I have a few more questions.
1) When the program is running my main frame lies within a progress frame
which displays "Enter data or press ESC to end" at the bottom. When you
press ESC the program closes but the progress login shows up along with the
procedure editor. Is there a key event like "ON ESC" that I can use to
handle this?
2) Because the program is run from the desktop it creates temporary files on
the desktop. Is there a way to direct these to a temp folder like maybe
vntgwork?
3) After the program is closed there remains one file on the desktop
rbrun.out. It looks like status info on how my report ran. Can I suppress
this file? Would it be one of the report engine parameters?
4) Does anyone have a sample of a simple error handeler to put into
procedures or triggers? Something like "on-error print err-msg".
TIA
Mark Dupuis
Ranor Inc.
Baby steps is misleading, I think you've made good progress. Get
it?. Good "Progress" ... get it? .............
*crickets*
OK, OK, I'll just stick to the subject....
1) I think you've created a dialog instead of a window. The 'Quit'
statement should still shut down the procedure editor. Try..
ON WINDOW-CLOSE OF FRAME FrameName Quit.
2, 3) My understanding is location defaults to the current working
directory. Try the '-T' parameter in the command line. (-T
c:\vntgwork)
4) Here's an error checking example, as used when compiling a
program...
compile value("c:\windows\desktop\ProgName.w") SAVE NO-ERROR.
IF ERROR-STATUS:NUM-MESSAGES > 0 THEN DO:
compilefail = compilefail + 1.
REPEAT j = 1 TO ERROR-STATUS:NUM-MESSAGES:
ErrorNumber = ERROR-STATUS:GET-NUMBER(j).
ErrorMessage = trim(ERROR-STATUS:GET-MESSAGE(j)," ").
end.
end.
Good luck,
Lonnie
--- In vantage@y..., "Mark Dupuis" <dupuism@r...> wrote:
> Hello 4GL'ers
gets a date from
info in
file with
a .csv file
closes
progress frame
When you
with the
to
> handle this?
temporary files on
maybe
> vntgwork?
desktop
suppress
into
> TIA
> Mark Dupuis
> Ranor Inc.
Lonnie, actually my progress has been very slow..... :)
1) My program only has one frame, defined as frame1. When I run the
program it appears as a child in a progress window. I would imagine I can
establish some GUI environment settings that would suppress the progress
window. I downloaded a reports.w file from the group site and when you open
the file with the procedure editor and press f2 the program starts clean, no
parent progress window behind it. I am not familiar with all the key words
being used. Before I dissect this program would you happen to have, in its
simplest form, code for an empty frame that when run with f2 is the only
thing that you see, no parent progress window. BTW What's the difference
between a .p and a .w file?
2) I tried the -T parameter in my shortcut and my .pf file in different
locations. Nothing changed. I still get the temp files defaulting to my
desktop.
3) Status file problem solved. I found by using prntrb2 instead of printrb
the last parameter will let me direct the status file to another location.
4) Thanks for the sample error check.
TIA
Mark Dupuis
Sent: Monday, January 14, 2002 4:35 PM
Subject: [Vantage] Re: 4GL Baby steps
*crickets*
c:\vntgwork)
program...
end.
end.
Good luck,
Lonnie
Hello 4GL'ers
gets a date from a user along with number of days and then runs a report
using this
info in the filter. I have a desktop shortcut (Thanks Thaddeus) and a .pf
file with the database info. (Thanks Jim) When the program runs it creates
a .csv file on my desktop as planned. When the user clicks exit the program
closes along with the procedure editor. (Thanks Mark)
progress frame which displays "Enter data or press ESC to end" at the
bottom.
When you press ESC the program closes but the progress login shows up along
with the procedure editor. Is there a key event like "ON ESC" that I can use
to handle this?
temporary files on the desktop. Is there a way to direct these to a temp
folder like
maybe vntgwork?
desktop rbrun.out. It looks like status info on how my report ran. Can I
suppress this file? Would it be one of the report engine parameters?
into procedures or triggers? Something like "on-error print err-msg".
> TIA
> Mark Dupuis
> Ranor Inc.
Mark,
I used ProVision AppBuilder to generate code for a window and added a
quit to close Procedure Editor. I'll upload it now. If you post a
message when you grab it, I'll remove from 'source code' section of
files.
About the -T parameter, this is the actual command line I tested
which placed the srt, lbi and RBOut files on desktop as directed..
F:\epic50\progress\bin\prowin32.exe vantage -q -N TCP -H Bdc_lon -S
epic50 -T c:\winnt\profiles\administrator\desktop -p
x:\inventor\catalog\c-win.w
Lonnie
the
I can
progress
you open
clean, no
key words
have, in its
only
difference
different
to my
> desktop.
printrb
location.
> TIA
> Mark Dupuis
> From: lonniedrew [mailto:lonniedrew@c...]
> To: vantage@y...
> *crickets*
> c:\vntgwork)
> program...
ERROR.
(j)," ").
> end.
> end.
> Good luck,
> Lonnie
> Hello 4GL'ers
report
> using this
and a .pf
creates
the program
the
> bottom.
up along
I can use
> to handle this?
a temp
> folder like
> maybe vntgwork?
ran. Can I
parameters?
msg".
> > TIA
> > Mark Dupuis
> > Ranor Inc.
must have
Builder and
Lonnie,
I have it. This is what I was looking for. I do not have AppBuilder. It
would of taken days for me to work out this code. Thanks.
Mark
Sent: Tuesday, January 15, 2002 10:39 AM
Mark,
files.
Lonnie
the
I can
progress
you open
clean, no
key words
have, in its
only
difference
different
to my
> desktop.
printrb
location.
> TIA
> Mark Dupuis
> To: vantage@y...
> *crickets*
> c:\vntgwork)
> program...
ERROR.
(j)," ").
> end.
> end.
> Good luck,
> Lonnie
> Hello 4GL'ers
report
> using this
and a .pf
creates
the program
the
> bottom.
up along
I can use
> to handle this?
a temp
> folder like
> maybe vntgwork?
ran. Can I
parameters?
msg".
> > TIA
> > Mark Dupuis
> > Ranor Inc.
must have
Builder and
OK 4GL'ers I have another question. What a surprise!
My 4GL runs fine from my desktop shortcut that points to a .pf on the
servers mapped drive W:. When I create this shortcut on another workstation
and run it the program starts ok. My GUI comes up and the user can make
entries in the fields. When he selects the run button I get this error:
"UNABLE TO INITIALIZE THE DATABASE ENGINE: MSGOPEN: UNABLE TO OPEN MESSAGE
FILE: PROMSGS".
This error is from the rb engine. I use prntrb2 in my program to create a
csv file. Does anyone have an idea of why I get this message? I hope this
is my last hurdle to get over.
BTW Lonnie the -T option seems to work for other 4GL programs I tried. My
guess is because I direct prntrb2 to output to my desktop it also sets this
as a default location.
Mark Dupuis
make sure the user has the progress client installed... That's usually the
problem when I get this error.
Can the user run custom report builder links from the vantage menu?
Thaddeus
Sent: Tuesday, January 15, 2002 1:54 PM
Subject: RE: [Vantage] Re: 4GL Baby steps
the
FILE: PROMSGS".
Mark Dupuis
I usually see this when there is an error in the shortcut (forgot the -pf when using a .pf file) or the hosts and services file.
Reinstall clientsetup?
Jim
> FILE: PROMSGS".
> Mark Dupuis
The -T parameter tells Progress where to store its temporary files (.lbi
.srt, as previously noted; there are sometimes others, depending on what
you are doing). If used, it should always point to a location on the
machine where the process is running. If -T is not used these files will
be created in the working directory specified in your start up icon.
The "Unable to open PROMSGS" error happens when the process can't find
the file which contains all of the Progress error messages. By default
this is $DLC/promsgs, where $DLC is where you installed Progress. You
can point to another location by setting the environment variable
PROMSGS before you start Progress. There is no startup parameter for
this one, since Progress needs to be able to find this file to report
problems before it starts processing the startup parameters.
There is, for all practical purposes, no difference between .p and .w
files. .p was the original extension used in the character world to
identify Program files. When the GUI world came along, the .w extension
was introduced to identify programs that were intended to run in the GUI
world (in those days Progress V7 supported MS Windows or x-Windows
Motif). However there is nothing that prevents you from creating GUI
programs, and giving them a .p extension, or character programs with a
.w. (Personally, I recommend sticking to the conventions).
Specialists in Progress Databases and Software since 1986
William E. Colls william@...
PROComputer Systems Tel 613 591 0079
67 Willow Glen Dr. Fax 613 591 3924
Kanata Ontario Canada www.procomsys.com
K2M 1T1
