2 stub check Blank Title 52779
I forgot to mention the layout from top to bottom is Stub\Check\Stub
The lower stub is a sub-report, the upper stub and check are the header.
Of Gerard Wadman
Sent: Friday, October 27, 2006 12:47 PM
Subject: RE: [Vantage] Re: 2 stub check
I modified the canned Crystal check into a two stub check.
It works very well but the only downside is that we can't fit as many
line items on it, this wouldn't be a problem except for the fact that
Vantage fails to recognize that two pages have been written and doesn't
skip a number.
As a work around, any APs with more than 17 line items are entered
exclusively in their own batch, fortunately for us that doesn't happen
very often.
Behalf
Of robertjardim
Sent: Friday, October 27, 2006 11:57 AM
Subject: [Vantage] Re: 2 stub check
We have been trying to get the same thing.
The check is on the top followed by two stubs, which are exactly the
same.
If anyone has an example that works with Vantage 8 perhaps they can
post it up in the user group files section.
Has anyone created an AP check wihtwo stubs where both stubs show the
same info?
We've done it for many customers. But we've done it with Crystal forms, not Progress.
De : vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] De la part de David
Envoyé : 26 octobre 2006 14:26
À : vantage@yahoogroups.com
Objet : [Vantage] 2 stub check
same info?
Hi David,
I asked this question a while back and someone sent me a 2 stub check
off-line.
It was designed with Crystal 8.5 and it looks like it's for Vantage 6.1
and I haven't had a chance to convert it for Vantage 8 but if you want I
can forward you what I have to get you started.
Joe Rojas
IT Manager
TNCO, Inc.
781-447-6661 x7506
jrojas@...
Of David
Sent: Thursday, October 26, 2006 2:26 PM
Subject: [Vantage] 2 stub check
same info?
Curious why?
----- Original Message -----
Sent: Thursday, October 26, 2006 2:25 PM
same info?
Yes,
I it's a Crystal Report, and I used a subreport for the second part of
the check.
> same info?
Because we prefer using a laser check with 2 stubs, of which we keep one.
_____
Robert Christian
Sent: Thursday, October 26, 2006 12:35 PM
Subject: Re: [Vantage] 2 stub check
Curious why?
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
same info?
same.
We had a two stub check done in Crystal Reports that worked just fine
until a patch that was applied about six month ago. I have tried to
retool that report to no avail, so we're back to a one stub check.
Joe, I would appreciate a look at your two-stub form to see if I can
get it to work for us, or at least glean some insight into how to
make ours work. Thanks'
James Moore
LCEI
954-861-2828
--- In vantage@yahoogroups.com, "Joe Rojas" <jrojas@...> wrote:
> Hi David,
check
> off-line.
6.1
want I
> Thanks,
> Joe Rojas
> IT Manager
> TNCO, Inc.
> 781-447-6661 x7506
> jrojas@...
Behalf
> Of David
the
> same info?
I'd also appreciate seeing that report
David Fishman
AZ BLOCK 2000, LLC
520-744-3890
_____
jmoore33309
Sent: Friday, October 27, 2006 9:07 AM
James Moore
LCEI
954-861-2828
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Joe
> Hi David,
check
> off-line.
6.1
want I
> Thanks,
> Joe Rojas
> IT Manager
> TNCO, Inc.
> 781-447-6661 x7506
> jrojas@...
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
> Of David
the
> same info?
skip a number.
very often.
Of robertjardim
same.
