I think there may be a 2 stub check in the files section of this group.
I went through something very similar during my first implementation of
V8 and had the same results as Mark. We changed our process and went
with the standard check format.
Of Mark Wonsil
Sent: Tuesday, July 27, 2010 1:27 PM
Subject: Re: [Vantage] 2 Stub AP Check
to help you out.
However, during our implementation, we had the same request but we
ended up changing our process:
- Print standard checks
- Copy checks w/VOID watermark
Advantages:
- Eliminated the step of ripping off stub to attach to paid invoices.
Copies are already separated and sorted in check order.
- Check copy is same size as invoices, makes our files "flatter" and
not "lumpy" on one side.
- Does not break if you have more than one stub worth of invoices
which...
- Saves on checks because you can print more invoices per check which...
- Saves money because check stock is more expensive to print on than
copy paper
- Less work required for each Epicor upgrade (no custom report to
maintain)
Disadvantage:
- Culture shock (This isn't how we used to do it...)
Some food for thought...
Mark W.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-1264 | fax: 781-341-5694
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Of Mark Wonsil
> I have a 2 stub AP Check (format is Stub 1, Stub 2, Check). I haveVantage 8.03.305L. I would like the invoice
> detail to print on both stubs. Does anyone have a Crystal Report thatprints this way and would be willing to share
> their .rpt file?There are few folks here that have done this and will probably be able
to help you out.
Advantages:
which...
copy paper
maintain)
Disadvantage:
Mark W.
