You may need to reboot your workstations for them to be able to see the
server.
Gary Polvinale
Denton ATD
Sent: Thursday, November 08, 2001 8:03 PM
Subject: Re: [Vantage] 1432 Error - Could not connect to server...
check-n settings
server.
Gary Polvinale
Denton ATD
check-n settings
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, November 06, 2001 4:45 PM
Subject: [Vantage] 1432 Error - Could not connect to server...
> Hi --
> I am getting an error: Could not connect to server for database
> V:\Vantage\db\vantage, errno 0 (1432). This error just started
> happening on Friday, and appears to happen twice/day, at around 8:50
> AM and 11:30 AM. The message will last for about 50 minutes, then
> magically goes away and people can then login to Vantage. People who
> are in Vantage when this happens are not affected - they can continue
> to work without problem. Any idea what might cause this?
> We are running Vantage v5.0.332 on a Windows 2000 server. When we
> have this problem, it affects everyone (Win9x, Win2000 desktops,and
> the Win2000 server). It has happened pretty consistently for the
> last three days. The only change we really made was that on Thursday
> I talked to support and we optimized the database. The changes took
> affect Thursday nite when I restarted our server. In the process we
> added a group in the Progress Explorer Tool under
> defaultConfiguration called ODBCgroup, that was for our ODBC
> connections. Talking to support, they tell me that this should not
> be the problem, that a 1432 error is a network error.
> Any help would be greatly appreciated.
> Thanks.
> Lance Ekum
> Sentry Equipment Corp
> lance@...
> 262-567-7256 x131
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
