10.2.700.8 Quick Launch Financial Access
Upgraded over the weekend and any Kinetic Homepage user who got the quick launch by default can access AR and AP. Have a call open with Epicor, but wondering if anyone else has seen this. It is not in the menu, but can be launched from the widget.
It does not respect the security of Menu Maintenance.
I upgraded to 700.9
/me runs to check…
panting …
I can confirm you can do it in 700.9 as well.
For those “curious users” I deleted the quick launch to get them to a blank slate again and then they cannot add back. Now I know its not just me, thanks. I let them know another user is also experiencing.
I did the same. Removed the financial and all the “entry” links.
@mmcwilliams, It looks like if they are explicitly denied access to that program/process then it will not let them in. If they are implicitly denied through assignation of the menu group then they can open it.
Also, if you choose to “Change User”, you lose everything on the screen.
I now have a Problem Number! Hopefully this will be fixed soon.
