Write to SQL table from within BPM/Directive
All right here’s a way to do that same thing without breaking any rules in your BPM replace that INSERT Statement with something like this (not suggesting you should do that you’ve made your position clear, just adding this as a reference for the next guy to do it “RIGHT” ← notice the quotes not ragging on ya :wink:
using(var ud01svc = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.UD01SvcContract>(Db))
                         var ud01NewDS = new UD01Tableset();
                         ud01svc.GetaNewUD01(ref ud01NewDS);
                         var newUD01Row = ud01NewDS.UD01.Where(r=>r.Added()).FirstOrDefault();
                         newUD01Row .Key1= "NextIndex";
                         newUD01Row .Shortchar01 = msg;
                         ud01svc.Update(ref ud01NewDS);
Same exact outcome, but coloring within the lines :stuck_out_tongue:
