Win2000 Question
Wayne,
If you can ping the local host, the problem might be in your hub or
switch or possibly your cable. Check the connections and swap out your
patch cable and try a different port on your hub.
Wayne Cox wrote:
> Hi All... was hoping someone out there with more Win2000 experience than
> myself might be able to help with a problem.
> I have installed it on a new machine, and cannot get any IP networking to
> function. It has DHCP enabled, and is able to retrieve all its settings
> from the server (verified though IPCONFIG /ALL) It also passes the 3Com
> NIC diagnostics, including being able to broadcast to other 3Com NICs.
> However, it can't see any other hosts on the LAN. Even the most simple
> things - PINGing a server by IP address fail. Tried bypassing the DHCP and
> setting static parameters for all the TCP/IP stuff, but still the
> same. Also swapped in a different NIC, to no avail.
> Any ideas?
> -Thanks, Wayne Cox
> [sorry if this comes through twice - I'm stuck using an alternate email client]
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
John Himebaugh, MIS
InterOcean Systems, Inc.
3540 Aero Court
San Diego, CA 92123
Voice: 858.565.8400
Fax: 858.268.9695
Any ideas?
-Thanks, Wayne Cox
