ok I just published a new version to visual studio code store V 43 (may take a minute or two to show up for update / download)
That should fix this issue for SSO. I can’t test it in 500 myself but I believe it is fixed. I was able to test it in a different SSO version.
Download the new version of the extension, close Visual Studio Code , re-launch, re-open a customization and try again
I downloaded both the new VS Code version (now 0.44) and the latest helper library files. I am no longer seeing the errors due to themes but still having issues when trying to debug. When trying to use dnSpy nothing happens, again could be my setup, have not dug into that yet. When I use Visual Studio to debug I am getting a Win32 exception
"System.ComponentModel.Win32Exception was unhandled
Message: An unhandled exception of type ‘System.ComponentModel.Win32Exception’ occurred in System.dll
Additional information: The system cannot find the file specified
I have sporadic success with some customizations downloading (opening) and others not, seems to be screens that are sub-screens of others that do not open. For instance I have a customization on the ShiftSelect form which opens from the Clock In process of MES, It is named the same as the main MES form customization, Part Tracker and Part Tracker - Where Used same thing. I use blank dashboards as blank forms to write my own custom applications inside Epicor and those also do not want to open, or download into the Epicor\Customs folder.
Thanks Scott,
The issue with the regular Epicor Debugging i’m guessing has to do with the fact that it wants you to run it from Epicor (not much I can do I’ll poke about a little but I doubt I’ll be able to fix that)
DNSpy “nothing happens”… Can you send me a little more info on your setup for that?
Also your profile says you are in 10.1.500 is that the version you are testing this on? It appears something changed in the subforms from 10.1.X to 10.2.X so I’ll see if I can figure that out.
Thanks for this. Intellisense sorely missed in epicor.
Question: As a developer that works on every version of Epicor out there for clients,
do you have any tips on managing libraries for each version ? Do you see an optimal setup
scenario to address this ?
I downloaded and tested this out today and so far it is awesome! One thing that I noticed is that it clears out all saved comments on the Customization (when you click save and can add notes/comments about what was changed). I keep a log of what I’ve changed and when so that I can go back and review if necessary. Not a huge problem, but would be beneficial to be able to keep that log of saved notes/comments. Thanks!
Also, do you think you could allow the addition of comments into that Save comments box when we sync up? If not, no big deal, but would just be a nice bonus feature. Thanks again for all you have done with this so far!
Using 10.2.300, I had it all setup and working in VS Code a month or so ago. When I went back to try and use it yesterday to debug something, I keep getting this:
I’ve uninstalled, and reinstalled the VS Code extension.
I’ve cleared the local cache folder that is specified under settings.
It’s downloading the files to the local cache, and I can see the code within VS - but not able to use the “debug”
That message has always been there happens when the code is changed in epicor and not on VS Code just letting you know stuff may get over-written
But clicking past it should work
