Can you paste the actual error you're receiving? We're missing something
here.
If you want, send me a copy of your customization (off-list so it doesn't
get stripped) and I'll load it on my side and see what's up.
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
here.
*John Driggers*
*:: 904.404.9233
:: waffqle@...
On Wed, Oct 10, 2012 at 8:08 PM, bw2868bond <bwalker@...>wrote:
> I wonder if you are having problems because you are changing a field
> inside of a field change event handler......
> --- In vantage@yahoogroups.com, Neil Buckman <nbuckman@...> wrote:
> > Thanks Brian,
> > I tried that and although it compiled correctly and all it still came
> back with a different error this time:
> > Error Detail
> > Property 'Chars' is ReadOnly.
> > Stack Trace
> > at
> Microsoft.VisualBasic.CompilerServices.NewLateBinding.ResolveCall(Container
> BaseReference, String MethodName, MemberInfo[] Members, Object[] Arguments,
> String[] ArgumentNames, Type[] TypeArguments, BindingFlags LookupFlags,
> Boolean ReportErrors, ResolutionFailure& Failure)
> > at
> Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateIndexSetComplex(Object
> Instance, Object[] Arguments, String[] ArgumentNames, Boolean
> OptimisticSet, Boolean RValueBase)
> > at Script.UD06_AfterFieldChange(Object sender, DataColumnChangeEventArgs
> args)
> > at System.Data.DataColumnChangeEventHandler.Invoke(Object sender,
> DataColumnChangeEventArgs e)
> > at System.Data.DataTable.OnColumnChanged(DataColumnChangeEventArgs e)
> > at
> Epicor.Mfg.BO.UD06DataSet.UD06DataTable.OnColumnChanged(DataColumnChangeEventArgs
> e)
> > at System.Data.DataRow.set_Item(DataColumn column, Object value)
> > at System.Data.DataRowView.SetColumnValue(DataColumn column, Object
> value)
> > at System.Data.DataRowView.set_Item(String property, Object value)
> > at Epicor.Mfg.UI.FrameWork.EpiNumericEditor.TextValidate(Object sender,
> CancelEventArgs ea)
> > Private Sub UD06_AfterFieldChange(ByVal sender As Object, ByVal args As
> DataColumnChangeEventArgs)
> > ' ** Argument Properties and Uses **
> > ' args.Row("FieldName")
> > ' args.Column, args.ProposedValue, args.Row
> > Dim edvUD06 As EpiDataView =
> CType(Me.oTrans.EpiDataViews("UD06"),EpiDataView)
> > Dim edvUD06Row As System.Data.DataRow = edvUD06.CurrentDataRow
> > Dim CodeType As String = edvUD06Row("Key1")
> > Dim START as Integer = args.ProposedValue
> > Select Case args.Column.ColumnName
> > Case "Number01"
> > If CodeType <> "PARTS" then Exit Select
> > Dim pa As PartAdapter = New PartAdapter(UD06Form)
> > pa.BOConnect()
> > ...Code here...
> > pa.Dispose()
> > edvUD06Row.BeginEdit
> > edvUD06Row(0)("Character01") = TheAnswer
> > edvUD06Row.EndEdit
> > End Select
> > - Neil
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf Of Brian Roberts
> > Sent: Thursday, 11 October 2012 12:17 AM
> > Subject: RE: [Vantage] VB error in edit statement
> > You're missing the row number parameter, the (0) below:
> > edvUD06Row(0)("Character01") = "MYTEXT"
> > Brian.
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
> > Of nbuckman@...<mailto:nbuckman%40ymail.com>
> > Sent: Wednesday, October 10, 2012 7:39 AM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] VB error in edit statement
> > Am I blind? The code below throws an error at the edit statement saying
> > that conversion of "MYTEXT" to Integer is not valid.
> > Why is it doing that? Any suggestions welcome...
> > Dim edvUD06 As EpiDataView = CType(Me.oTrans.EpiDataViews("UD06"),
> > EpiDataView)
> > Case "Number01"
> > ...CODE HERE...
> > edvUD06Row("Character01") = "MYTEXT" <== crashes here
> > edvUD06Row.EndEdit
> > End Select
> > End Sub
> > - Neil
> > Notice:This e-mail and any attachments are confidential and are only for
> the use of the person to whom they are addressed. If you are not the
> intended recipient please advise the sender by return e-mail and delete the
> message and any attachments. Any use, interference with, disclosure or
> copying of this message or any attachments is unauthorised and prohibited.
> The sender does not warrant that the information is free of a virus or any
> other defect or error, and any views expressed herein, unless specifically
> indicated otherwise, are those of the individual sender.
> > The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
> > P Please consider our shared environment before printing this
> communication.
