Hello All,
When I create a Sales Order Detail I would like to copy Part.Checkbox01 into OderDtl.Checkbox02. I’ve tried using the following code in a BPM, Method Code: SalesOrder.GetNewOrderDtl, Pre-Processing with “Actions” “sychronously execute 4GL code”. This is my code:
/* Copy Part.Checkbox01 to OrderDtl.Checkbox02 */
For Each ttOrderHed where ttOrderHed.Company =cur-comp,
Each ttOrderDtl where ttOrderDtl.Company = ttOrderHed.Company and ttOrderDtl.OrderNum = ttOrderHed.OrderNum no-lock.
Find First Part where ttOrderHed.Company = Part.Company and ttOrderDtl.PartNum = Part.PartNum no-error.
If available (Part) then Do.
ttOrderDtl.Checkbox02 = Part.CheckBox01.
End.
@jmannett I also did this in 9 on ChangePartNumberMaster with code similar to yours. I have never seen 8 so can you do a trace to see what methods are called when adding a line and part to the order? If not what Change methods do you have available?
This is what I don’t understand. I’m using SalesOrder.ChangePartNum. In Post-Processing I create an informational message in the Actions. Then I add my 4GL Code as in my previous post. Then I added an other informational message behind it. My results are when I add a new line item to the sales order and add the Part Number, I will get the two informational messages, but I will not get the Part.Checkbox01 to copy to the OrderDtl.Checkbox02.
If I do the same thing in SalesOrder.Update with Post-Processing. When I make any change to the order and save, I get the informational messages and it copies the Part.Checkbox01 to OrderDtl.Checkbox02 as I want. Any ideas what I’m doing wrong?
Here is how I did this and I added a couple of things I do for tracing. I swapped out my variables for yours, so this should work. I started with ttOrderDtl since this in on ChangePartNum I don’t think you would have or need ttOrderHed.
Also if you use ``` before and after code it will format better.
The Message statements write to you appserver server log. I think it has to be running in verbose mode.The info message will do a popup and shows you are in your custom code.
On Change you want post processing since you are between the database and the client. On update you want pre-processing since you are going from the client to the database.
This is all from 905 and I hope it works in 8.
/* set CB02 from part CB01 */
Message " IN ChangePartNum get cb01".
define variable InfoMsg as character init ''.
For Each ttOrderDtl where ttOrderDtl.company = cur-comp.
For First Part fields (CheckBox01) where Part.PartNum = ttOrderDtl.PartNum.
Assign ttOrderDtl.Checkbox02 = Part.CheckBox01.
Message " IN ChangePartNum assign cb01".
InfoMsg = "I made it to the assigment".
{lib/PublishInfoMsg.i &InfoMsg = InfoMsg}.
End.
End.
Thanks for the information. I haven’t had a chance to try it yet. I did get one of my BPM’s to work, but when I re-created it in my Live Vista it didn’t work. Why would that be? I originally created the BPM in my Training database. When I had it working like I wanted it to, then I unenabled it in my Training database and created it in my Live database and now it doesn’t work.
