A little thing, and hopefully I am not the only one, but I am used to the behavior:
Double Click = select/highlight current word
Triple Click = select/highlight entire field contents.
Epicor does not support the Triple Click = Select All behavior and it drives me crazy.
I’ve had users ask about this as well.
It is most annoying in the Search Panel in the Modern UI and I triple click to select all and type over the value… but it doesn’t work, so I smash that Backspace key.
A little thing, but it’s all the little bumps along the way that makes for a rough road.
Good point. I’ve sent this up the chain – I’ll let you know if it gets on the backlog.
