We have been using this for daily reporting, but no warranty. Please validate the data. There are some cases where Time Phase calculates Sales Orders/Jobs before the PO Qty on Lines for Running Total. I argued with Epicor about this but, for the most part you should get the same results as Time Phase from epicor.
Here is the RDL. You will have to define which part numbers you want to show in the parameter under default values, or modify it another way to make it produce the data you want.
TimePhaseRDL.zip (7.6 KB)
BONUS BAQ
I haven’t used this file for a long time, i dont know if it works or not.
kpEngineAvail_0517 (2021).baq (33.2 KB)
