Here are the steps I go through to replace my certificate for Kinetic. Maybe this will help you.
Create Certificate Request in IIS.
Use the CSR to request a new certificate
Download the new certificate from the certificate authority.
NOTE- Before installing the new certificate, you must be prepared to complete ALL the following steps. Failure to complete ALL the steps may prevent the Kinetic app pool from restarting. Since the app pools will be recycled during this process, it is recommended to complete this process when it is unlikely to disrupt users.
Install the new certificate on the server using the Complete Certificate Request⌠function. Give the new certificate a friendly name that allows you to distinguish from the certificate being replaced.
Open the Epicor Administration Console
Open the properties of the Kinetic server (NOT the app pool).
Click the ⌠button to change the certificate to the new certificate and save changes.
Open Application Server Configuration
Switch to the Extensions > Enterprise Search tab.
Click the ⌠to change the SSL Certificate.
Click Deploy, then OK.
Close Epicor Administration console
In IIS Manager - delete the certificate that is being replaced.
Cycle the app pools on the server to make sure that they restart.
IIRC, Kinetic can get confused if there are multiple certificates with the same subject name. I recommend you delete the expired cert.
ALL will need to be added to Root Trusted Authority on workstations attempting to access this resource AND these generated certificate files will need tied to IIS bindings.
Here is bash âone-linerâ with open SSL example good for 10 yrs :
param (
[Parameter()]
[string]$certname=$($env:COMPUTERNAME), ## Identify the Host this cert is being generated for if not supplied.
[Parameter()]
[string]$dnsname=$($env:COMPUTERNAME+"."+$env:USERDNSDOMAIN ) , ## Build a fqdn we hope if one is not supplied.
[Parameter()]
[string]$pwd = "Please set a password!",
[Parameter()]
[string]$path = "C:\certs" ## Default path to store generated certificate(s)
$dnsname = $($dnsname).ToLower()
$mypwd = ConvertTo-SecureString -String $pwd -Force -AsPlainText ## Private Key password
$cert = New-SelfSignedCertificate -Subject "CN=$certname" -CertStoreLocation "Cert:\localmachine\My" -KeyExportPolicy Exportable -KeySpec Signature -KeyLength 2048 -KeyAlgorithm RSA -HashAlgorithm SHA256 -DnsName $dnsname -NotAfter (Get-Date).AddYears(2)
Export-Certificate -Cert $cert -FilePath "$path\lm_$certname.cer" ## Specify your preferred location
Export-PfxCertificate -Cert $cert -FilePath "$path\lm_$certname.pfx" -Password $mypwd ## Specify your preferred location
$certfile = (Get-ChildItem -Path "$path\lm_$certname.cer")
$certfile | Import-Certificate -CertStoreLocation cert:\LocalMachine\Root ## Install into Trusted Root
Echo ""
Echo "Please remember to install into IIS and set the bindings for SSL and attach to this cert."
Powershell (openssl3) example: (EDITED to add export to pfx which will import into IIS correctly)
$configFile=@'
[req]
distinguished_name = req_distinguished_name
x509_extensions = v3_req
prompt = no
E = webmaster@server.internal.domain
[req_distinguished_name]
C = US
ST = State
L = City
OU = Org Unit
O = Org, Inc.
CN = server.internal.domain
[v3_req]
keyUsage = critical, digitalSignature, keyEncipherment, dataEncipherment
extendedKeyUsage = serverAuth, clientAuth
subjectAltName = @alt_names
[alt_names]
DNS.1 = server.internal.domain
DNS.2 = *.server.internal.domain
$configFile | Out-File -Encoding UTF8 server.internal.domain.config.txt
cmd.exe /c "openssl req -x509 -newkey rsa:4096 -sha256 -days 3650 -nodes -keyout server.internal.domain.key -out server.internal.domain.crt -extensions v3_req -config server.internal.domain.config.txt"
cmd.exe /c "openssl pkcs12 -password pass:MySuperSecretPassword -nomac -keypbe PBE-SHA1
-3DES -certpbe PBE-SHA1-3DES -export -out server.internal.domain.pfx -inkey server.internal.domain.key -in server.internal.domain.crt"
Get-Content server.internal.domain.crt, server.internal.domain.key | Set-Content server.internal.domain.pem
ALL of these should work as I have USED all of them to create self-signed certs for various projects/needs. This should only be used IF you cannot use something like Letâs Encrypt
All of these create the key element needed to work properly when used for internal SSL encryption here it is:
Simplest method to install cert to TRCA for Local Machine is:
Click lock in browser address bar (probably with red line through it) and (export/copy to file) the certificate to a local folder.
Locate the exported certificate file and (right click or double click to) install certificate
This will bring you to the Certificate Import Wizard
Click Local Machine then Next
Just to be clear, if the certificate comes from a Certificate Authority that is already in the trust chain (Letâs Encrypt, DigiCert, etc.) then this step is not necessary, like Clint says above.
If you plan to use Postman with a self-signed cert, then youâll have to make more adjustments there too. If you use any third party connections (Azure, I assume Workato, etc.), then youâll have to copy your cert to those services as well.
