I think this one should be fairly straight forward…i’m writing a BPM to return standard text. The bpm works, however in the field i want the text to appear it returns it as one continuous string.
How do i write the syntax in the bpm to display the text in this format…
“text line 1”
“text line 2”
“text line 3”
instead of it showing “text line 1 text line 2 text line 3”
Thank you in advance. (i did check that the field in question is set to multi-line so i think this is just how to write the syntax within the bpm)
