Depends on the number of users you plan to connect. I got a starter
license which supports 5 consecutive connections for about $1000...
Paul
lheisey@...]
Sent: Friday, January 05, 2001 11:52 AM
To: '
vantage@egroups.com'
Subject: RE: [Vantage] Terminal Server
Is Citrix not expensive?
paul.siebers@...]
Sent: Friday, January 05, 2001 10:34 AM
To: '
Make sure you get MetaFrame's Citrix.... Makes things a lot easier to
manage...
lheisey@...]
Sent: Friday, January 05, 2001 9:08 AM
To:
vantage@egroups.com
Subject: [Vantage] Terminal Server
I need direction in getting my clients connected through terminal
server. I have TS installed on the server and the client installed
on the workstation. When I attempt to connect the connection times
out. Perhaps it is the adding of the user to terminal server and
some type of permissions that are wrong. Can anyone give me some
tips please?
please go to the following link:
http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password,
the link above will work the next time you try it.)
to
Groups,
choose Vantage, then choose Files. If you save the password, the link
above
