Subassembly and Scheduling
Epicor will backward schedule until it hits today, then it will forward schedule from today IF you have "do not allow dates in the past" checked (which is logical).  Try raising the priority and it will schedule ahead of other jobs in the time frame you want.
Georgia
---In vantage@yahoogroups.com, <scottyk537@...> wrote:
How much time is you sub assembly being scheduled? You will see this scenario if the part is not configured correctly and cannot make the due date because the sub assembly takes too much time. Try setting the due date on the job to sometime next year and reschedule.
Scott
On Fri, Oct 4, 2013 at 1:56 PM, <nhoyt111@...> wrote:
<div>
  <p>&nbsp;No, that&#39;s the kicker.&nbsp; I have 4 on hand.<var></var></p>
---In vantage@yahoogroups.com, <vantage@yahoogroups.com> wrote:
Is there an expected receipt date for a material used to make anything in that subassembly?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of nhoyt111@...
Sent: Friday, October 04, 2013 1:29 PM
Subject: [Vantage] Subassembly and Scheduling
Good Afternoon,
We are trying to start using the scheduling engine in 9.05.607B. I am finding that where we have a subassembly and I run for backwards scheduling, the subassembly gets forward scheduled from today and then the rest of the operations backwards scheduled. The only way this doesn't happen is if I manually reschedule and override material constraints. this isn't a stock part, so I wouldn't even think that material constraint would come into account.
Has anyone worked with scheduling and assemblies and come up with a method that works? Has anyone discovered any bug in this area?
Thanks very much,
nancy
</div>
<div style="color:rgb(255,255,255);min-height:0px;"></div>
Good Afternoon,
Thanks very much,
nancy
Rob Bucek
FAX: (715)284-4084
Good Afternoon,
Thanks very much,
nancy
 No, that's the kicker.  I have 4 on hand.
Rob Bucek
FAX: (715)284-4084
Good Afternoon,
Thanks very much,
nancy
And just to be sure, that on hand qty exceeds demand for entire company? Just on a hunch, try changing job scheduling priority code to one that doesn’t have the minimize wip checked as true then reschedule. Are you moving this thru the Job Scheduling board?
Rob Bucek
FAX: (715)284-4084
Sent: Friday, October 04, 2013 1:56 PM
Subject: RE: RE: [Vantage] Subassembly and Scheduling
Rob Bucek
FAX: (715)284-4084
[cid:1.234354861@...<mailto:1.234354861@...>]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>] On Behalf Of nhoyt111@...<mailto:nhoyt111@...>
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Good Afternoon,
Thanks very much,
nancy
Â
Scott
Â
<div>
  <p><p> No, that&#39;s the kicker.  I have 4 on hand.<var></var></p>
Rob Bucek
FAX: (715)284-4084
Good Afternoon,
Thanks very much,
nancy
</div>
