An empty RowMod means the row is unchanged. I THINK – but it’s been a while – that when you Save/Update a record Epicor sends two data rows: one is the original, unchanged row (with RowMod blank) and the other is the updated row (with RowMod = “U”). If you get the count of rows in ttQuoteDtl, is it more than 1? Or if you use a foreach loop, does one of the rows have a “U” RowMod?
This code below is from a Standard directive and loops through each updated row and uses this fact to get the old values that were changed. The loop is for each updated row, and the FirstOrDefault methods select the passed rows that are unchanged – the original data before the update was called.
just to fill out the reason… when you UPDATE a record, there are always TWO records… the unmodified record (rowmod = “”) and the modified record (rowmod = “U”)… this allows BPMs to look for events like “when a field has changed from X to Y”… the only way to do this is to have a copy of the before/after values of all the fields. So, you always need to search for the Modified value, or the new value (rowmod = “A”) when doing work. Many times, I personally shortcut this and simply look for rowmod <> “”
