jorel
(Jakob Orel)
9
Here are some screenshots of where you will need to edit the RDL dataset query in Report Builder:
Follow the syntax in the dataset already to get the field from the table you would like.
Then, you will have to add it in as a query field:
This post has some more info about editing MtlTag.
Like @gpayne said, make sure you create duplicate/new RDD and RDLs as to not affect other areas that use this MtlTag dataset.
