SSRS Label Printing via HH
Is your print server the same server that your Epicor Task Agent is running on? We had the same problem, and needed to install the printer on (and share it from) the same server as the Task Agent. See point 2 under “Guidelines to Implementing Server-Side Printing in Your Environment” below:
