“Guilty pleasure tabbers” - they use tabs because it’s so satisfying and really the correct way to do things but want to look cool and edgy in front of their JS/Python friends.
Also, just going to leave this here to fan the flames…
If your editor is converting your tabs to spaces, then no reason. If your editor is storing the tabs in the file and other users have different tab stops, your pretty file ends up unreadable.
So youy’re saying you exclusively use the space key, and change the number of spaces you indent to match the existing code (when modifying someone else’s)?
