So thatâs after you double clicked the row, changed it to A (the row should then be yellow) then you clicked updated, and thatâs where you are at when you get this message?
Also, did you go find the record in T&E and just see if you can approve it there?
Yes
Double click
Yellow Row
Make Change
Hit UPDATE button
Get error message.
So in time and expense, it doesnât let you approve it there? (basically is it posted?)
Yes, I think I can do it through time and expenseâŚ
Since have several to clean up just trying the BAQ.
Thanks for the help.
Generally, you would only want to use this when you canât do it in time and expense. (After itâs posted.)
thanks
Hello,
i had this problem in epicor 9 , the time status would not change from E to A in my BAQ update image|690x408
