[SOLVED]Open Qty Adjustment via button click on Dashboard
Hello all,
I have created a dashboard & added a button ‘Adjust Quantity’. This button needs to open up the Quantity Adjustment Menu. I’ve added the Custom Control & Control Event for this button but I’m having issue with the Code.
LaunchFormOptions lfo = new LaunchFormOptions();
lfo.IsModal = false;
lfo.SuppressFormSearch = true;
ProcessCaller.LaunchForm (oTrans “Erp.UI.InventoryQtyAdjEntry”, lfo);
I get the following error: Error: CS0103 - line 62 (142) - The name ‘oTrans’ does not exist in the current context
Am I missing something? This is code that I got from the “Epicor ICE 3.0 Customization User Guide” btw
Thank You
Tevin
Is this a runtime dashboard or an assembly (deployed dashboard)?
It is a Dashboard-Runtime
Ok well, I figured out what I was doing wrong. I had to create the dashboard without customizing the tracker view. Add it as a dashboard assembly. Then open the dashboard in the menu where I placed it. Then apply the customization
Thank you so much for putting the solution here. I was trying to do a dashboard refresh and was running into the ‘The name ‘oTrans’ does not exist in the current context’ error.
On a related note - I just shared some code that does QtyAdjustments via code on another thread.
