Screen Resolution w/citrix
"Change the windows color scheme to large or extra large fonts.
If you are using win98 also change to large icons. While this
won't affect Vantage it does seem to cut down the complaints."
This seems to be a good solution. Thank you and all for the response.
"Reilly, Rhonda" wrote:
> A majority of our users are using 14-15 in monitors with a screen resolution
> of 800x600. With those settings the users are having a problem seeing the
> whole vantage screens when they are using citrix. I assume changing the
> monitor resolution would work but I am not sure how many users would be
> acceptable to a higher resolution (the complaints then would be that they
> can't read the screen because it's fonts and such are too small). Does
> anyone know of a solution to this. Any help would be appreciated.
> Thanks
> Rhonda
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
I beg to differ.
Unless there's something different about Citrix, or unless Epicor has
changed their programming standards, if you use large fonts you will end up
losing text on the screen. It may not be readily apparent because sometimes
entire words disappear. We ran into this when we first implemented Vantage
and had a heck of a time figuring out what the problem was.
Steve Sanders
Delta Centrifugal Corp.
There's something different about Citrix.
adrian
Sent: Tuesday, August 15, 2000 11:07 AM
To: vantage@egroups.com
Subject: RE: [Vantage] Screen Resolution w/citrix
I beg to differ.
Steve Sanders
From what I understand of the screen resolution try this. Open up the
Citrix program neighbourhood icon. Highlight your connection ICA client and
right click. Choose connection properties, options tab. In the windows
properties section of this options tab you will see the ability to change
the window size. Try changing it here for each user of Citrix. Hope this
helps.
Frank D'Andrea
Pine Valley Packaging Ltd.
Sent: Tuesday, August 15, 2000 11:23 AM
Subject: [Vantage] Screen Resolution w/citrix
Rhonda
_____
<http://click.egroups.com/1/8358/13/_/411782/_/966353146/>
<http://adimg.egroups.com/img/8358/13/_/411782/_/966353146/>
_____
<http://www.egroups.com/files/vantage/>
