Probably. Report Builder might be able to do it in theory, but even
if it can your users will have to be very patient people. Even
Crystal using a single query will be a challenge, as the query is
complex and some of the needed joins across the job / invoice related
tables are not well indexed. It will depend on the volume of jobs and
invoices you have to deal with, of course, but if you find it's
really bogging down, consider a couple of smaller queries into Access
that create job side and invoice side tables separately and then
reporting against them. Our invoice and job volume is very large, and
this is the kind of thing that eventually drove us to using 4GL push
exports to external apps.
good luck,
John
good luck,
John
--- In vantage@yahoogroups.com, Gordon Schindell <gordons@a...> wrote:
> John,
> I'll try using Report Builder first. Think I'll have to go to
Crystal for
> this?
> Gord
> -----Original Message-----
> From: johnahannaford [mailto:johnh@p...]
> Sent: Thursday, September 04, 2003 2:05 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Sales and costs impossible to get in Vantage?
> Gordon,
> What reporting tool are you using?
> John
wrote:
> > John, thanks for this. I'm going to try re-building cost and
> revenue
> > reports using jobasmbl table as per below...
> > Sent: Wednesday, September 03, 2003 9:01 AM
Vantage?
> > Doesn't seem all that hard, unless I'm misunderstanding your
> > requirement.
> > 1. Get the required job cost data - jobasmbl has the current
> > summaries - create a unit cost from that, per job number.
> > 2. Get the required invoice information, create a unit revenue
per
> SO
> > line from that, reference the packing slip.
> > 3. Join the cost and revenue data on the lot information in the
> > packing slip if you ship from inventory, or the job number if you
> > ship from the job. We're inventory based, so we use the job
number
> as
> > the lot number to make this connection simple. It's even more
> obvious
> > if you ship from the job.
> > We don't typically slice it at the SO line level, more usually
it's
> a
> > customer/part/month view, but there's no reason you couldn't as
> long
> > as the invoice export contains the fields. I use my own Progress
> > applets to get the data and manipulate it from a menu choice, but
> you
> > could use the export utility, or an ODBC connection to feed
tables
> > that could be used in Crystal or Access as well.
> > The reporting has been the easy part. Getting production to enter
> the
> > cost data correctly (or at all) is the real test.
> > regards,
> > John
must have
Builder and
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
