Run batch file when Epicor starts
Of-course it is fixed in 10.1, everything else is *grin*
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Fri, Sep 25, 2015 at 11:18 AM, Stephen Edginton stephene@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>
Be aware not clearing does cause some issues in E10.
I was told it will be fixed in 10.1 but not tested yet.
On 25 Sep 2015, at 15:53, Ted Koch tkoch77@... [vantage] <vantage@yahoogroups.com> wrote:
Â
These settings in the config file can also be changed so it will take a split second to pull the custom files.
 <deploymentSettings>
   <deploymentServer uri="\\server\ERP10.0.700Deployment" />
   <deploymentType value="zip" options="xcopy|zip" />
   <deploymentPackage value="ReleaseClient.zip" />
   <!-- only used when deployment type is zip -->
   <doDateComparison value="True" bool="" />
   <!-- set to false and the deployment will copy all files from the -->
   <!-- deployment server, set to true and the deployment will use -->
   <!-- date comparison to do the copy -->
   <clearClientDir value="Never" options="Never|Always|Prompt" />
   <!-- Determines if the client install directory is cleared prior to doing an update -->
   <clearDNS value="Always" options="Never|Always|Prompt" />
   <!-- Determines if the local client cache is cleared prior to doing an update. -->
   <optimizeAssemblies value="false" bool="" />
   <!-- this setting requires the user to have admin rights on their machine -->
 </deploymentSettings>
From: "Joshua Giese jgiese@... [vantage]" <vantage@yahoogroups.com>
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Friday, September 25, 2015 10:46 AM
Subject: RE: [Vantage] Re: Run batch file when Epicor starts
That’s the spirit! Tell them to replace that few minutes with some wasteful Facebook time they maybe would have used an hour later when it’s all working fine J
Â
Joshua Giese
Technology Solutions : CTO
Direct Phone:Â Â Â 920.593.8299
Office Phone:Â Â Â 920.437.6400 x342
http://wcibags.com/email/emailFooter4.jpg
Sent: Friday, September 25, 2015 9:32 AM
Subject: Re: [Vantage] Re: Run batch file when Epicor starts
Â
Â
I don't plan on doing it often, but I know in the past when I've done upgrades users complain about needing to wait for a few minutes. They'll just have to deal with it.
Â
From: "Jose Gomez jose@... [vantage]" <vantage@yahoogroups.com>
To: Vantage <vantage@yahoogroups.com>
Sent: Friday, September 25, 2015 9:09 AM
Â
Â
Even if it downloads the whole entire client, in a local LAN it takes just a minute or two. Do you plan on doing this often?
Jose C Gomez
Software Engineer
Â
On Fri, Sep 25, 2015 at 7:57 AM, Ted Koch tkoch77@... [vantage] <vantage@yahoogroups.com> wrote:
Â
Maybe I have something wrong in my sysconfig file then, when I trigger Epicor to download client files it downloads the whole lot.
Â
From: "s1mhall@... [vantage]" <vantage@yahoogroups.com>
Sent: Thursday, September 24, 2015 8:05 PM
Subject: [Vantage] Re: Run batch file when Epicor starts
Â
I guess the question is how often, how much and what sort of network connectivity do you have. This scenario works for us, but then again our custom folder only has 22mb of files in it, you could halve that due to the copies. I recall it only copies over the newer files only if I recall correctly.
Cheers
Simon Hall
Â
Â
Stephen Edginton (Beng) | Solutions & Technical Director
Mobile: Â +44 7734 858415
DDI: Â +44 121 314 1179
Main: Â +44 (0) 121 314 1170
Web: Â www.dotnetit.co.uk
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
DotNetIT
Epicor Platinum Partner
Epicor Alliance Partner
</div>
<div style="color:#fff;min-height:0;"></div>
Great. Do you know what issues it causes?
From: "Stephen Edginton stephene@... [vantage]" <vantage@yahoogroups.com>
To: "<vantage@yahoogroups.com>" <vantage@yahoogroups.com>
Sent: Friday, September 25, 2015 11:18 AM
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 #ygrps-yiv-76790160yiv2309575225 --
#ygrps-yiv-76790160yiv2309575225 .ygrps-yiv-76790160yiv2309575225ygrp-photo-title{
clear:both;font-size:smaller;height:15px;overflow:hidden;text-align:center;width:75px;}
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225ygrp-photo{
background-position:center;background-repeat:no-repeat;background-color:white;border:1px solid black;height:62px;width:62px;}
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225photo-title
a,
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225photo-title a:active,
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225photo-title a:hover,
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225photo-title a:visited {
text-decoration:none;}
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225attach-table div.ygrps-yiv-76790160yiv2309575225attach-row {
clear:both;}
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225attach-table div.ygrps-yiv-76790160yiv2309575225attach-row div {
float:left;}
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 p {
clear:both;padding:15px 0 3px 0;overflow:hidden;}
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225ygrp-file {
width:30px;}
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225attach-table div.ygrps-yiv-76790160yiv2309575225attach-row div div a {
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225attach-table div.ygrps-yiv-76790160yiv2309575225attach-row div div span {
font-weight:normal;}
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 div.ygrps-yiv-76790160yiv2309575225ygrp-file-title {
font-weight:bold;}
#ygrps-yiv-76790160 #ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 P.ygrps-yiv-76790160yiv2309575225b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 {
MARGIN:0cm 0cm 0pt;}
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 LI.ygrps-yiv-76790160yiv2309575225b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 {
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 DIV.ygrps-yiv-76790160yiv2309575225b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 {
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 TABLE.ygrps-yiv-76790160yiv2309575225b1e7fd89-0279-4ffe-a16a-1f1bcba0d537Table {
#ygrps-yiv-76790160 #ygrps-yiv-76790160yiv2309575225 DIV.ygrps-yiv-76790160yiv2309575225Section1 {
Joshua Giese
Direct Phone:    920.593.8299
Office Phone:    920.437.6400 x342
Jose C Gomez
Software Engineer
Cheers
Simon Hall
Mobile:  +44 7734 858415
DDI: +44 121 314 1179
Main:  +44 (0) 121 314 1170
Web:  www.dotnetit.co.uk
DotNetIT
