Resource Group Scheduling Board
Hello, when viewing the resource scheduling board, I only see unfirmed jobs out to 12/2. I run the resource scheduling board out 4 months. I should be seeing unfirmed jobs out to February. Any idea why this may be happening ? Is there a setting where the resource scheduling board can see further out ?
Thank You
Kevin H.
Are you scheduling your long range plans via rough-cut scheduling? That doesn’t populate the resources with hours.
Gil, thanks for responding. No, our unfirmed jobs out in the future are created via MRP.
I don’t think that alone is enough to determine the method MRP is using to schedule those jobs. I’m not that experienced with rough-cut scheduling, however, but the documentation states that rough-cut schedules do not load resources.
