Todd:
The scenario is this, upper and lower are similar sized blocks
(Press platens heated with steam) steel block under 2800 pounds of
compression. At any given moment if the steam stops, with only the 4 sides
exposed to 80 to 100 degrees ambient how long before the block reaches 280
degrees F.
(Rubber being cured in a block of steel, cure time at 325F is 15 to 30
minutes)
Shirley
_____
Sent: Monday, October 11, 2004 12:10 PM
Subject: RE: [Vantage] OT Heat dissipation of Steel
Would those ambient temperatures be below or above freezing?
Since only the sides are exposed what's above and below? More steel at
325F?
Sent: Monday, October 11, 2004 10:51 AM
Subject: [Vantage] OT Heat dissipation of Steel
For all of you Steel guys, approximately how long would it take a block
of
steel 24" x 24" x10" to cool from 325F to 285F with no heat applied and
only
the sides exposed to ambient temperatures. To make this easier, pick
one of
the choices below.
1. 1 - 5 minutes
2. 5 - 10 minutes
3. 10 - 15 minutes
4. 15 - 20 minutes
5. 20 - 25 minutes
Shirley Graver
Sys Admin
Rubber Associates
Tracking #: 4E49A51CFEFD92449EB957815A87A6F6E650FFFF
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129gtdq6k/M=295196.4901138.6071305.3001176/
D=groups/S=1705007183:HM/EXP=1097596343/A=2128215/R=0/SIG=10se96mf6/*htt
p://companion.yahoo.com>
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=group
s/S=:HM/A=2128215/rand=353349980>
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129mj8k7u/M=294855.5468653.6549235.3001176/D=gr
oups/S=1705007183:HM/EXP=1097597384/A=2376776/R=0/SIG=11ldm1jvc/*http:/promo
tions.yahoo.com/ydomains2004/index.html> click here
<http://us.adserver.yahoo.com/l?M=294855.5468653.6549235.3001176/D=groups/S=
:HM/A=2376776/rand=146484461>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
degrees F.
minutes)
Shirley
_____
325F?
of
only
one of
the choices below.
1. 1 - 5 minutes
2. 5 - 10 minutes
3. 10 - 15 minutes
4. 15 - 20 minutes
5. 20 - 25 minutes
Shirley Graver
Sys Admin
Rubber Associates
ADVERTISEMENT
click here
Yahoo! Groups Links
ADVERTISEMENT
_____
Yahoo! Groups Links
