Report Parameters Help
Try the following:
  1. Customize the Credit Card Report form, adding a date control. Bind it to CallContextBPMData.Date01
  2. Nothing need to be done in the RDD
  3. In the copy of your CC Report RDL, edit the Query expression for dataset CreditTran. Add the highlighted parts below:
The RDD will use the native date from the form to limit the lower (oldest date), and the additions to the Query expression limit the upper end date.
I haven’t tried the above - as we don’t process credit cards. But a similar approach works on another built-in form and report.
edit
I re-uploaded the pict after fixing a missing space : (...+ " T2 )
