Report Builder question
Not sure if I completely understand the question but I'll take a stab at it. The Part.StdMaterialCost field will reflect the current standard at a given point in time (right?). So it carries no history of what it was earlier in time. I have a report I must do for our auditors on raw material costs that has the similar requirement of needing to compare the cost at the end of the year with the cost at the beginning. Two ways I have approached this are:
1. Restore database from last year's end of year backup to our "Test" database, extract Part Num and Cost to Access DB table, extract current cost to another table, link and report change (for some sort of LIFO factor our auditors user). Could be difficult if you have upgraded during the year and restored DB needs to be converted (schema changes, etc...).
2. A Report Builder report that exams all the part's purchases and takes earliest one in the year and compares to current raw material cost. Not 100% accurate if first purchase in year was, say, in June. But good enough to compare cost change over the year.
Since you are looking for material costs going into a Part you might be able to reconstruct from all the jobs for the part in each year. Perhaps from the JobMtl table? You could then add up 2003 material costs (based on Jobs Closed in 2003?) and divide by Qty and compare to the current standard cost in the Part table. Might this work? Like #2 above not 100% but probably pretty close.
-Todd C.
Sent: Wednesday, April 07, 2004 9:04 AM
To: VantageGroup (E-mail)
Subject: [Vantage] Report Builder question
Hey All
Is it possible to write a report that would compare last years
Part.StdMaterialCost with the current Part.StdMaterialCost. I'm drawing a
blank. If you give a date range for 2003 to pick up last years cost how do
you get the current cost ?? I'm sure someone has figured it out.
Cliff Drumeller
IT Manager
Mass Precision Sheetmetal
408 954 0200 x 217
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12c7mbktq/M=291630.4786521.5933964.1261774/D=egroupweb/S=1705007183:HM/EXP=1081433185/A=2072415/R=0/SIG=11thh7ako/*http://www.netflix.com/Default?mqso=60178432&partid=4786521> click here
<http://us.adserver.yahoo.com/l?M=291630.4786521.5933964.1261774/D=egroupweb/S=:HM/A=2072415/rand=482719576>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
At first I thought it would not be possible, but as I thought it about it
more you might be able to get to it from part-tran and filter or select on
adj-cst transaction.
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Sent: Wednesday, April 07, 2004 10:04 AM
Hey All
Cliff Drumeller
IT Manager
408 954 0200 x 217
ADVERTISEMENT
_____
Yahoo! Groups Links
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the views of the sender and not necessarily the views of the company. The email and any files transmitted with it are confidential to the intended recipient at the e-mail address to which it has been addressed. It may not be disclosed or used by any other than that addressee, nor may it be copied in any way. If received in error, please delete and notify the sender via e-mail or sales@... quoting the name of the sender. Messages sent via this medium may be subject to delays, non-delivery and unauthorized alteration. This e-mail has been prepared using information believed by the author to be reliable and accurate. Unless expressly stated otherwise, this e-mail does not form part of a legally binding contract or agreement between recipient and Innovative Office Products, Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the use of this email or attachments. It is, therefore, your responsibility to scan attachments (if any).
Cliff
StdMaterialCost is in the Part Table and contains the current value.
MtlUnitCost is in the PartTran Table and contains the material costs
for parts you had transactions for.
If you build a report based on the PartTran Table joined to the Part
Table. Sort on PartNum. Filter for a TranDate range and use average,
minimum or maximum to agregate the MtlUnitCost you can compare the
material costs for part you transactions for.
If you want compare this years tranactions with last years
transactions Use calculated fields
LastYearMtlCost = iif(TranDate >= 1/1/03 AND TranDate <= 12/31/03,
MtlUnitCost, 0)
ThisYearMtlCost = iif(TranDate >= 1/1/04 AND TranDate <= 12/31/04,
MtlUnitCost, 0)
Then average, minimum or maximum those to get your comparison.
HTH
RUss Dover
To: "VantageGroup (E-mail)" <vantage@yahoogroups.com>
> Hey All
> drawing a
> how do
> Cliff Drumeller
> IT Manager
> 408 954 0200 x 217
> access. )
You could turn on the change log maintenance for
Part.StdMaterialCost. This will create a record in the Chglog table
for any changes made to the Std Material Cost. Won't help for last
year but maybe in the future.
Andy Berg
National Tube Form
260-478-2363 x 211
--- In vantage@yahoogroups.com, Cliff Drumeller <cliff@m...> wrote:
> Hey All
years
drawing a
cost how do
> Cliff Drumeller
> IT Manager
> 408 954 0200 x 217
You could turn on the change log maintenance for Part.StdMaterialCost. This
will create records in the Chglog table for any changes made to the Std
Material Cost. It won't help for last year but maybe in the future.
Andy Berg
National Tube Form
260-478-2363 ext 211
andy.berg@...
Sent: Wednesday, April 07, 2004 10:28 AM
Subject: Re: [Vantage] Report Builder question
Cliff
MtlUnitCost, 0)
MtlUnitCost, 0)
HTH
RUss Dover
> Hey All
> drawing a
> how do
> Cliff Drumeller
> IT Manager
> 408 954 0200 x 217
> access. )
_____
Yahoo! Groups Links
<http://docs.yahoo.com/info/terms/> Service.
