Ah, but you are on a form with a BAQ view… I thought you were using a dashboard because you’re posting on a thread called “Refresh Kinetic Dashboard after Custom Action.”
Remove the parenthesis from the Where clause. Everything else looks fine (assuming the cut off portion looks similar)
Sorry @utaylor this thread had the closest answers for using the BAQ widget in terms of refreshing a view of some kind.
I could have sworn I wrote the where clause in every possible way with or without the parenthesis, and yet this worked instantly thanks as always.
Hi Jose, Thanks for your sharing! it is simple and useful!
