If you are using UD Column Map Maintenance, here is some more information on each mappings Functional Process.
Map ID | Source | Target | Valid | Functional Process |
1 | JobPart | ECOCoPart | Yes | EWB - Get Details from a Job Template |
2 | PartCoPart | ECOCoPart | Yes | EWB - Updating a revision, Get Details from a Method |
3 | QuoteCoPart | ECOCoPart | Yes | EWB - Get Details from a Quote Template |
4 | JobAsmbl | ECOMtl | Yes | EWB - Get Details from a Job Template |
5 | JobMtl | ECOMtl | Yes | EWB - Get Details from a Job Template |
6 | Part | ECOMtl | Yes | EWB - Add a new Material to a MOM |
7 | PartMtl | ECOMtl | Yes | EWB - Updating a revision, Get Details from a Method |
8 | QuoteAsm | ECOMtl | Yes | EWB - Get Details from a Quote Template |
9 | QuoteMtl | ECOMtl | Yes | EWB - Get Details from a Quote Template |
10 | JobOper | ECOOpr | Yes | EWB - Get Details from a Job Template |
11 | PartOpr | ECOOpr | Yes | EWB - Updating a revision, Get Details from a Method |
12 | QuoteOpr | ECOOpr | Yes | EWB - Get Details from a Quote Template |
13 | WrkCenter | ECOOpr | Yes | EWB - Adding a new operation |
14 | PartRev | ECORev | Yes | EWB - Updating a revision |
19 | JobAsmbl | JobAsmbl | Yes | Job Entry - Get details from a template job |
20 | JobMtl | JobAsmbl | No | |
21 | Part | JobAsmbl | Yes | Job Entry - Adding a new Assembly |
22 | PartMtl | JobAsmbl | Yes | Job Entry / MRP / Job Manager / CTP/ Any other process creating a job - Get details from a Method |
23 | PartRev | JobAsmbl | Yes | Job Entry / MRP / Job Manager / CTP/ Any other process creating a job - Get details from a Method |
24 | QuoteAsm | JobAsmbl | Yes | Job Entry - Get details from a Quote Template |
25 | QuoteMtl | JobAsmbl | No | |
26 | JobAsmbl | JobMtl | No | |
27 | JobMtl | JobMtl | Yes | Job Entry - Get details from a Job Template |
28 | Part | JobMtl | Yes | Job Entry - Add a new Material to the job |
29 | PartMtl | JobMtl | Yes | Job Entry / MRP / Job Manager / CTP/ Any other process creating a job - Get details from a Method |
30 | QuoteAsm | JobMtl | No | |
31 | QuoteMtl | JobMtl | Yes | Job Entry - Get details from a Quote Template |
32 | JobOper | JobOper | Yes | Job Entry - Get details from a Job Template |
33 | PartOpr | JobOper | Yes | Job Entry / MRP / Job Manager / CTP/ Any other process creating a job - Get details from a Method |
34 | QuoteOpr | JobOper | Yes | Job Entry - Get details from a Quote Template |
35 | WrkCenter | JobOper | Yes | Job Entry - Manually add a new operation |
36 | JobPart | JobPart | Yes | Job Entry - Get details from a Job Template |
37 | PartCoPart | JobPart | Yes | Job Entry / MRP / Job Manager / CTP/ Any other process creating a job - Get details from a Method |
38 | QuoteCoPart | JobPart | Yes | Job Entry - Get details from a Quote Template |
64 | DMRActn | MscShpDt | Yes | When creating a misc shipment using a DMR marked as “Return to supplier” |
61 | DMRHead | MscShpHd | Yes | When creating a misc shipment using a DMR marked as “Return to supplier” |
63 | DemandDetail | OrderDtl | Yes | When process demand from actions menu on Demand Entry and the Sales Order is created. |
62 | DemandHead | OrderHed | Yes | When process demand from actions menu on Demand Entry and the Sales Order is created. |
60 | DemandSchedule | OrderRel | Yes | When process demand from actions menu on Demand Entry and the Sales Order is created. |
15 | ECOCoPart | PartCoPart | Yes | EWB - Check in a method |
16 | ECOMtl | PartMtl | Yes | EWB - Check in a method |
17 | ECOOpr | PartOpr | Yes | EWB - Check in a method |
18 | ECORev | PartRev | Yes | EWB - Check in a method |
39 | JobAsmbl | QuoteAsm | Yes | Quote Entry - Get Details from a Job Template |
40 | Part | QuoteAsm | Yes | Quote Entry - Adding a new Assembly |
41 | PartMtl | QuoteAsm | Yes | Quote Entry - Get Details from a Method |
42 | PartRev | QuoteAsm | Yes | Job Entry - Get details from a Method |
43 | QuoteAsm | QuoteAsm | Yes | Quote Entry - Get Details from a Quote template |
44 | QuoteMtl | QuoteAsm | No | |
45 | JobPart | QuoteCoPart | Yes | Quote Entry - Get Details from a Method |
46 | PartCoPart | QuoteCoPart | Yes | Quote Entry - Get Details from a Method |
47 | QuoteCoPart | QuoteCoPart | Yes | Quote Entry - Get Details from a Quote template |
59 | DemandDetail | QuoteDtl | Yes | When process demand from actions menu on Demand Entry and the Sales Order is created. |
58 | DemandHead | QuoteHed | Yes | When process demand from actions menu on Demand Entry and the Sales Order is created. |
48 | JobAsmbl | QuoteMtl | No | |
49 | JobMtl | QuoteMtl | Yes | Quote Entry - Get Details from a Job Template |
50 | Part | QuoteMtl | Yes | Quote Entry - Adding a new Material |
51 | PartMtl | QuoteMtl | Yes | Quote Entry - Get Details from a Method |
52 | QuoteAsm | QuoteMtl | No | |
53 | QuoteMtl | QuoteMtl | Yes | Quote Entry - Get Details from a Quote template |
54 | JobOper | QuoteOpr | Yes | Quote Entry - Get Details from a Job Template |
55 | PartOpr | QuoteOpr | Yes | Quote Entry - Get Details from a Method |
56 | QuoteOpr | QuoteOpr | Yes | Quote Entry - Get Details from a Quote template |
57 | WrkCenter | QuoteOpr | Yes | Quote Enrty - Adding a new Operation |
This topic is a Wiki feel free to correct any errors, or elaborate on Functional Process.
