RB Question
Are any fonts set really small, like under 6 or 7. I have see display
problems when the font size was set to 5 or 6.
Patrick Winter
Sent: Tuesday, April 08, 2003 10:36 AM
Subject: RE: [Vantage] RB Question
OK. I am nuts. I can get more of the description but not the entire thing
on some of the longer fields. I have the following setup:
Format: x(10000) - I am desperate
Width: 60
Word Wrap - Left.
Help! I am in a hurry. I am supposed to have this report done by now and
they want to see the FULL description.
Juliet
Sent: Tuesday, April 08, 2003 10:01 AM
That worked. Thanks. Something must have been screwy. I didn't even
change anything and it came up! Thanks everyone! I thought I was going
nuts.
Juliet
------------------------ Yahoo! Groups Sponsor ---------------------~--> Get
128 Bit SSL Encryption!
http://us.click.yahoo.com/xaxhjB/hdqFAA/VygGAA/PhFolB/TM
I had a calculation being performed on JobMtl.Description. I ran it
without being in a calculation. It came out fine. I read your e-mail
and noticed the odd characters you described. It seems that is indeed
my problem. A big thank you to everyone. I am grateful that all of
you. Your help is greatly appreciated.
Juliet
Sent: Tuesday, April 08, 2003 10:52 AM
1. I assume the Format is really 1,000 not 10,000. The database format
is only 1,000 so any extra may not do any good.
2. How was the text entered in the description field? If it was entered
with "Enter" (CR) at th end of lines rather than allowing to wrap
naturally it can cause problems getting it all to print. If I recall
the characters between the CR on a line (as it prints) and the end of
that line's width get counted as text for the format's size. So if you
have a really long description (nearing the 1000 character max) you can
lose some text. Does the text that does print have odd characters in it
(like shaded squares or rectangle boxes). This is an indicaiton they
entered "hard" returns. You might want to use a formula to strip out
all CR ( CHR(13) ) and replace with a space. Tab characters are also
good to replace ( CHR(9) ). Then use your calculated field (with all
the word wrapping etc..) to print.
-Todd C.
I have to pull a report based on a portion of the part description. I have
part descriptions such as -15"x150' Punched Black or 15"x750' Punched Black.
A sales guy wants a report that shows how much 150' material he sold last
year. The only way I can think of doing that would be to somehow filter on
parts that the description contains 150'. Problem is I have no clue how to
make that happen. Anyone care to help?
Todd Hofert
IT Director
Spartan Graphics, Inc.
I'm not sure how to do this with report builder, but if you use MS access,
you can use the filter: Like "*150*" and that will give you the results you
want.
The only way you can really approach this is using the substring
function. Its success is predicated on whether or not the description
entry is done in a consistent manner. That is, does the 150 ALWAYS
appear at the end of the description with a ' at the end or does "1"
ALWAYS the 5th character in the description. Otherwise, your results
will be inconsistent.
Shirley Graver
Sys Admin
Rubber Associates Inc.
Sent: Tuesday, May 13, 2003 10:38 AM
To: Vantage List (E-mail)
Subject: [Vantage] RB Question
have
Black.
last
on
to
Todd Hofert
IT Director
ADVERTISEMENT
<http://rd.yahoo.com/M=253924.3294213.4590844.1261774/D=egroupweb/S=1705
007183:HM/A=1380983/R=2/id=noscript/*http:/companion.yahoo.com/config/fe
atures5>
<http://us.a1.yimg.com/us.yimg.com/a/ya/yahoo_companion/pop_lrec_back.gi
f>
<http://us.adserver.yahoo.com/l?M=253924.3294213.4590844.1261774/D=egrou
pmail/S=:HM/A=1380983/rand=599563109>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
Try adding a filter line "Part.PartDescription MATCHES '*150*'
Patrick Winter
Sent: Tuesday, May 13, 2003 9:38 AM
Todd Hofert
IT Director
cOOL Patrick, I forgot about wild cards.
Shirley
Sent: Tuesday, May 13, 2003 11:00 AM
Patrick Winter
have
Black.
last
on
to
Todd Hofert
IT Director
have
and
ADVERTISEMENT
atures5>
f>
pmail/S=:HM/A=1380983/rand=630683004>
Patrick/Sarah,
You are the man/woman. This is perfect. I can find many uses for this.
The suggestion for substring is useful as well however wouldn't work in this
situation because the 150 does not always appear in the same place in all of
my descriptions.
Thanks to all
Todd
Patrick Winter
Todd Hofert
IT Director
Hello Group,
What's key sequence to display the progress code generated by report
builder?
At 02:16 PM 9/30/2004, you wrote:
>What's key sequence to display the progress code generated by report builder?
Don't have RB handy to try; but try either ctrl-F11 or alt-F11. IIRC it's
one of those. It should actually be SQL you're seeing.
-Wayne Cox
Twenty Three -- Information Technology Consulting
828-685-2338
Looked up an old post. Ctrl-Alt-P then F12 to show the SQL code.
-Todd C.
Sent: Thursday, September 30, 2004 1:25 PM
Subject: Re: [Vantage] RB Question
-Wayne Cox
828-685-2338
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129h4v7dq/M=295196.4901138.6071305.3001176/D=groups/S=1705007183:HM/EXP=1096655165/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=:HM/A=2128215/rand=215016275>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
That's not working, I remember it was something like ctrl-F11 then "p" but I
can't seem to get it to show the SQL.
Patrick
builder?
-Wayne Cox
828-685-2338
Yahoo! Groups Links
Try CTRL ALT p, then F12.
David Kaufman
CNC Metals
A Global Body Co.
> From: pjw@... [SMTP:pjw@...]
> Sent: Thursday, September 30, 2004 2:57 PM
> Patrick
> From: Wayne Cox [mailto:wmc20@...]
> builder?
> -Wayne Cox
> 828-685-2338
> Yahoo! Groups Links
> Yahoo! Groups Links
David,
Thanks, no wonder I couldn't get it to work CTRL ALT p runs my print screen
program.
Patrick Winter
Sent: Thursday, September 30, 2004 2:06 PM
David Kaufman
CNC Metals
A Global Body Co.
> but I can't seem to get it to show the SQL.
> Patrick
> builder?
> it's one of those. It should actually be SQL you're seeing.
> -Wayne Cox
> 828-685-2338
> Yahoo! Groups Links
> Yahoo! Groups Links
------------------------ Yahoo! Groups Sponsor --------------------~-->
$9.95 domain names from Yahoo!. Register anything.
http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/PhFolB/TM
Yahoo! Groups Links
Does this work only for user written report build reports?
If not, when do you press the key combination?
I tried doing it before and after I printed the stock status report but I just keep getting the Program call list.
This tool would be of great help.
Jeremy
Sent: Thursday, September 30, 2004 3:17 PM
David,
program.
Patrick Winter
David Kaufman
CNC Metals
A Global Body Co.
> Patrick
> builder?
> -Wayne Cox
> 828-685-2338
> Yahoo! Groups Links
> Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Load the report in report builder like your going to edit it, then do the
key combo.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.20.322, Progress 9.1D, Windows 2003 Server, Crystal 8.5.3.975
Sent: Thursday, September 30, 2004 2:44 PM
Jeremy
David,
program.
Patrick Winter
David Kaufman
CNC Metals
A Global Body Co.
> Patrick
> builder?
> -Wayne Cox
> 828-685-2338
> Yahoo! Groups Links
> and
> Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
I'm trying to create a report that compares last months inventory to this
months inventory. I can easily get the inventory using partbin. To get my
onhand quantity of the parts in the warehouses and bins and filter it to
what partclass, etc.
The question is: Can you pull what the quantity of the part was on a prior
date in the bin ? If so what table and joins would you use.
Cliff Drumeller
IT Manager
Mass Precision Sheetmetal
408 954 0200 x 217
