<div id="ygrps-yiv-502681497yiv2679307438ygrp-text"> <div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:12pt;background-color:rgb(255, 255, 255);"><div><span>job estimated costs (material/labor) are established at time of job detial generation (for material grabbing the then current cost of your raw material based on its costing method - so if a new item with no cost establlished, no estimate).</span></div><div><span></span> </div><div><span>actuals occur as transactions occur. Some of the trackers are funky (not always showing the right cost buckets by default). Try a narrow parttran query on the specific job/material bringing back all columns and see if it is there.</span></div><div><span></span> </div><div><span>You can also use job completion to temporarily complete a job with show production detial checked (all transactions) & that may reveal whether you really are not having valid material cost go
into WIP. (Uncheck
complete if job still in process afterwards.)on 8.03.409a, that is the most revealing job cost report I've found.Are you purchasing your materials direct to each job or purchasing to stock and then issuing to stock?If PO is zero priced, that is what will transfer into job (and I don't believe a valid posted invoice price will update WIP as it updates inventory).I'm out of ideas without more detail (version, cost method, etc.,).RobBrownVersaProducts
On Tuesday, October 15, 2013 5:00 AM, "tracy.smith@…" <tracy.smith@…> wrote:
<div id="ygrps-yiv-502681497yiv2679307438ygrp-text"> <div> Could it be that the Backflush Labor Server Process needs running?<var id="ygrps-yiv-502681497yiv2679307438yui-ie-cursor"></var></div> <div class="ygrps-yiv-502681497yiv2679307438ygroups-quoted"><br clear="none"><br clear="none">---In vantage@yahoogroups.com, <vantage@yahoogroups.com> wrote:<br clear="none"><br clear="none"><div id="ygrps-yiv-502681497yiv2679307438ygrps-yiv-768570915">Ok, I was just throwing out the idea… I don’t use it that way.<br clear="none">
Josh Serwe
Wisconsin Converting Inc.
Warehouse & Logistics Manager
(920)437-6400 x 330
Manasa Reddy
Sent: Monday, October 14, 2013 3:44 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] RE: Raw Material Cost in Job Production
It has nothing to do with average costing…..just so you know…
I came from a place that averaged costed and our costs flowed nicely. It is
something in her set up.
Manasa
Joshua Serwe
Sent: Monday, October 14, 2013 3:28 PM
Subject: RE: [Vantage] Raw Material Cost in Job Production
I don’t believe that Average costing will work if your raw materials are
backflushed. Try issuing them prior to entering the completed quantity to
see if that works.
Josh Serwe
(920)437-6400 x 330
Jacqueline Restivo
Sent: Monday, October 14, 2013 3:04 PM
Subject: Re: [Vantage] Raw Material Cost in Job Production
We are using average cost. All materials are still set up to backflush.
The material is dropping from inventory but the cost of material isn't
attaching to the pieces on the job. According to Epicor, it costs nothing
to produce these pieces.
Sent: Monday, October 14, 2013 1:00 PM
What type of costing are you using? Are you backflushing or issuing? I
believe Kanban auto backflushes raw materials (we do not use Kanban) but
each raw material part needs to be set up as a backflush on the jobs without
Kanban or you need to issue materials on a job to job basis.
Josh Serwe
(920)437-6400 x 330
Jacqueline Restivo
Sent: Monday, October 14, 2013 8:50 AM
Subject: [Vantage] Raw Material Cost in Job Production
Thanks Josh
We're graduating from Kanban to Job entry.
Wondering when does raw material attach a cost to the job? I produced 450
pieces but the cost to produce is showing $0.00 in Production Detail Report
and in Part Trans History.
The job is depleting inventory on the material, this material has a cost
attached to it.
Sent: Friday, October 11, 2013 4:00 PM
Subject: RE: [Vantage] Material Queue Manager
Hi Jaqueline,
The other 100 pieces will sit in WIP until you process them through the
material queue, a “Job Receipt to Inventoryâ€, or ship them on a “Make
Direct†release of an order that is linked to the job.
Josh Serwe
(920)437-6400 x 330
Jacqueline Restivo
Sent: Friday, October 11, 2013 8:11 AM
Subject: [Vantage] Material Queue Manager
In Epicor 905.606A MES module>Production>Report qty, I checked “request
move†for qty of 450 pieces and didn’t check the "request Move" for 100
pieces.
Only the 450 pieces moved to the Material Queue Manager list, I then
processed and put into inventory. Where are the other 100? It’s not in
inventory.
The only place I can see how many pieces were produced is the job tracker.
The Job Entry only shows the 450 received.
thanks in advance
jacqueline
[Non-text portions of this message have been removed]</div> <div style="height:0px;color:rgb(255, 255, 255);"></div></div>
</div>
<div id="ygrps-yiv-502681497yiv2679307438yqt51931" class="ygrps-yiv-502681497yiv2679307438yqt4532487922"><div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mkp #ygrps-yiv-502681497yiv2679307438hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mkp #ygrps-yiv-502681497yiv2679307438ads {
margin-bottom:10px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mkp .ygrps-yiv-502681497yiv2679307438ad {
padding:0 0;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mkp .ygrps-yiv-502681497yiv2679307438ad p {
margin:0;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mkp .ygrps-yiv-502681497yiv2679307438ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-sponsor #ygrps-yiv-502681497yiv2679307438ygrp-lc {
font-family:Arial;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-sponsor #ygrps-yiv-502681497yiv2679307438ygrp-lc #ygrps-yiv-502681497yiv2679307438hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-sponsor #ygrps-yiv-502681497yiv2679307438ygrp-lc .ygrps-yiv-502681497yiv2679307438ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438activity span {
font-weight:700;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438activity span span {
color:#ff7900;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438activity span .ygrps-yiv-502681497yiv2679307438underline {
text-decoration:underline;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 .ygrps-yiv-502681497yiv2679307438attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 .ygrps-yiv-502681497yiv2679307438attach div a {
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 .ygrps-yiv-502681497yiv2679307438attach img {
border:none;padding-right:5px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 .ygrps-yiv-502681497yiv2679307438attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 .ygrps-yiv-502681497yiv2679307438attach label a {
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 .ygrps-yiv-502681497yiv2679307438bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 .ygrps-yiv-502681497yiv2679307438bold a {
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 dd.ygrps-yiv-502681497yiv2679307438last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 dd.ygrps-yiv-502681497yiv2679307438last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 dd.ygrps-yiv-502681497yiv2679307438last p span.ygrps-yiv-502681497yiv2679307438yshortcuts {
margin-right:0;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div.ygrps-yiv-502681497yiv2679307438attach-table div div a {
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div.ygrps-yiv-502681497yiv2679307438attach-table {
width:400px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div.ygrps-yiv-502681497yiv2679307438file-title a, #ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div.ygrps-yiv-502681497yiv2679307438file-title a:active, #ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div.ygrps-yiv-502681497yiv2679307438file-title a:hover, #ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div.ygrps-yiv-502681497yiv2679307438file-title a:visited {
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div.ygrps-yiv-502681497yiv2679307438photo-title a, #ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div.ygrps-yiv-502681497yiv2679307438photo-title a:active, #ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div.ygrps-yiv-502681497yiv2679307438photo-title a:hover, #ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div.ygrps-yiv-502681497yiv2679307438photo-title a:visited {
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 div#ygrps-yiv-502681497yiv2679307438ygrp-mlmsg #ygrps-yiv-502681497yiv2679307438ygrp-msg p a span.ygrps-yiv-502681497yiv2679307438yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 .ygrps-yiv-502681497yiv2679307438green {
color:#628c2a;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 .ygrps-yiv-502681497yiv2679307438MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 o {
font-size:0;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438photos div {
float:left;width:72px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438reco-category {
font-size:77%;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438reco-desc {
font-size:77%;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 .ygrps-yiv-502681497yiv2679307438replbq {
margin:4px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mlmsg select, #ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 input, #ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mlmsg pre, #ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 code {
font:115% monospace;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-mlmsg #ygrps-yiv-502681497yiv2679307438logo {
padding-bottom:10px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-msg p#ygrps-yiv-502681497yiv2679307438attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-reco #ygrps-yiv-502681497yiv2679307438reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-sponsor #ygrps-yiv-502681497yiv2679307438ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-sponsor #ygrps-yiv-502681497yiv2679307438ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-sponsor #ygrps-yiv-502681497yiv2679307438ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-text {
font-family:Georgia;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-text tt {
font-size:120%;}
#ygrps-yiv-502681497 #ygrps-yiv-502681497yiv2679307438 #ygrps-yiv-502681497yiv2679307438ygrp-vital ul li:last-child {
border-right:none !important;}
