Priority Dispatch Report
I am getting an error
“Corrupt Next Peer Assembly Pointer JOB: I63574 Assy: 1 Pointer: 8”
I can find the job in job entry, and I can find Assy 1, which I assume is assembly 1, but what is pointer 8?
Also, there is no assembly 8 or 9, but there is 10-16, 2-7 are subs of 1 but the others are their own with no subs.
Thoughts?
I am assuming the pointer: 8 is looking for sub-assembly 8, which doesn’t exist because I assume someone deleted it…
Not sure this would work but I would be curious to know if removing the job from the schedule and rescheduling would allow the report to start working.
Thanks, we had actually tried that and it did nothing, I shouldn’t say did nothing, we weren’t able to remove it from the schedule.
The end solution we did, was something that I don’t think is described correctly, but this was the description.
when I deleted operations in inventory job I63574 it created an error so I changed to open and reports ran.
