The code below gets the printer settings from a BAQ I wrote that links user names to printers in the system and then submits the BAQ report to the System Agent.
private void PrintBillsSSRS(){
if (numBOLNum.Value == null || Convert.ToInt32(numBOLNum.Value) <= 0) { return; }
// Make sure the boxes and weight are up-to-date before printing
UpdateBOLBoxesAndWeight(Convert.ToInt32(numBOLNum.Value));
string[] printerInfo = GetDefaultPrinter(((Session)HHConfirmShipForm.Session).UserID);
string printer = printerInfo[0];
string pageSettings = printerInfo[1];
string printerSettings = printerInfo[2];
//MessageBox.Show("Printer: " + printer);
string agentID = "";
try
Session otSession = (Session)oTrans.Session;
//Set the workstationID
string workStation = Ice.Lib.Report.EpiReportFunctions.GetWorkStationID(otSession);
//Get or Set the AgentID
using (var aSA = new SysAgentAdapter(oTrans))
//oTrans.PushStatusText("Get System Agent Info", true);
aSA.BOConnect();
aSA.GetDefaultTaskAgentID(out agentID);
if (!string.IsNullOrEmpty(agentID)) { agentID = "SystemTaskAgent"; }
//MessageBox.Show(agentID + ", " + workStation);
for (int i =0; i < 3; i++)
var baqR = WCFServiceSupport.CreateImpl<Ice.Proxy.Rpt.BAQReportImpl>((Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.BAQReportSvcContract>.UriPath);
var dynamicReport = WCFServiceSupport.CreateImpl<Ice.Proxy.BO.DynamicReportImpl>((Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.DynamicReportSvcContract>.UriPath);
var rptMonitor = WCFServiceSupport.CreateImpl<Ice.Proxy.BO.ReportMonitorImpl>((Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.ReportMonitorSvcContract>.UriPath);
// GET DEFAULT REPORT PARAMETERS
var rptDs = dynamicReport.GetByID("PSG-tmsCustBOL");
var baqRptDS = baqR.GetNewBAQReportParam("PSG-tmsCustBOL");
baqRptDS.BAQReportParam[0].Option01 = numBOLNum.Value.ToString();
baqRptDS.BAQReportParam[0].AutoAction = "SSRSPRINT";
baqRptDS.BAQReportParam[0].WorkstationID = workStation;
baqRptDS.BAQReportParam[0].PrinterName = printer;
baqRptDS.BAQReportParam[0].RptPageSettings = pageSettings;
baqRptDS.BAQReportParam[0].RptPrinterSettings = printerSettings;
baqRptDS.BAQReportParam[0].SSRSRenderFormat = "PDF";
//baqRptDS.BAQReportParam[0].Character01 = numBOLNum.Value.ToString();
//baqRptDS.BAQReportParam[0].Character02=flag;
baqRptDS.BAQReportParam[0].BAQRptID = "PSG-tmsCustBOL";
baqRptDS.BAQReportParam[0].ReportID = "PSG-tmsCustBOL";
baqRptDS.BAQReportParam[0].Summary = false;
baqRptDS.BAQReportParam[0].ReportStyleNum = 1;
baqRptDS.BAQReportParam[0].BAQID = "PSG-tmsCustomerBOL";
baqRptDS.BAQReportParam[0].ReportTitle = "Bill of Lading";
//baqRptDS.BAQReportParam[0].TaskNote = guid.ToString();
rptDs.BAQRptOptionFld[0].FieldValue = numBOLNum.Value.ToString();
rptDs.AcceptChanges();
StringWriter writer = new StringWriter();
rptDs.WriteXml(writer);
baqRptDS.BAQReportParam[0].Filter1 = writer.ToString();
//baqR.RunDirect(baqRptDS);
baqR.SubmitToAgent(baqRptDS, agentID, 0, 0, "Erp.UIRpt.BAQReport");
//MessageBox.Show("Report Submitted to System Agent for processing.");
catch (Exception ex)
MessageBox.Show("An error occured trying to print report." + ex.Message);
// Gets the printer for the current user.
private string[] GetDefaultPrinter(string currentUser)
string[] output = new string[3];
string printer = string.Empty;
string pageSet = "Color=True,Landscape=False,PaperSize=[Kind=\"Letter\" PaperName=\"Letter\" Height=1100 Width=850],PaperSource=[SourceName=\"FormSource\" Kind=\"FormSource\"],PrinterResolution=[Kind=\"Custom\" X=600 Y=600]";
string printSet = "PrinterName=\"" + printer + "\",Copies=1,Collate=False,Duplex=Default,FromPage=1,ToPage=0";
// Special cases for PLT02 and PLT03, because we can only add 2 printers to each workstationID
if (currentUser.ToUpper().Equals("HH10") || currentUser.ToUpper().Equals("HH04"))
// PLT02. Default to PLT2-PR-02
printer = "\\\\PSG-SRV-02\\PLT2-PR-02";
output[0] = printer;
output[1] = pageSet;
output[2] = printSet;
return output;
} else if (currentUser.ToUpper().Equals("HH08") || currentUser.ToUpper().Equals("HH05") || currentUser.ToUpper().Equals("HH06"))
// PLT03. Default to PLT3-PR-06
printer = "\\\\PSG-SRV-02\\PLT3-PR-06";
return output;
DynamicQueryAdapter dqa = new DynamicQueryAdapter(oTrans);
dqa.BOConnect();
QueryExecutionDataSet qeds = dqa.GetQueryExecutionParametersByID("PSG_tmsPrinterForUser");
qeds.ExecutionParameter.Clear();
qeds.ExecutionParameter.AddExecutionParameterRow("UserID", currentUser, "nvarchar",false,Guid.NewGuid(), "A");
dqa.ExecuteByID("PSG_tmsPrinterForUser", qeds);
foreach (DataRow row in dqa.QueryResults.Tables["Results"].Rows)
// Only use printers that aren't label printers (do not contain "LBL")
if (!row["SysPrinter_PrinterID"].ToString().ToUpper().Contains("LBL"))
printer = row["SysPrinter_NetworkPath"].ToString();
pageSet = row["Calculated_PageSettings"].ToString();
printSet = row["Calculated_PrinterSettings"].ToString();
return output;
