Passing Report Parameters to a BAQ Report
Ahhh… I misunderstood. You parameter is truly an input and needs to be used inside the BAQ. Not as a “filter” on the results of the BAQ.
If you made the BAQ Report first, there’s a chance there’s a conflict in the Report Style’s Data Definition.
When you make a BAQ Report, that BAQReport ID becomes both the ReportID AND the Data Definition used in Report Style
A “blank” RDD will be created using that ReportID (E10H-Test in my example). I can add the BAQ and criteria sets and everything.
But back in Report Style, the Data Definition field dropdown only lists one entry for E10H-Test. Is that for the BAQ Reprot or the RDD?
