We can take @olga’s idea and make a work-around while you file a ticket. Instead of using the Has Hold condition, you can create a query from OrderDtl → Part → BPHoldAttachment and select if you have at least one record when filtering for your hold type. Basically, you’re doing the same query that “The hold…is attached to ERP.Part.”
