My one big hang up with implementing wireless is its less than desirable
security. Needless to say, we will have wireless this year with or
without a comfortable level of security. I have read numerous white
documents on this issue and do not get a good feeling from any solution
other than setting up an internal firewall which the Wireless hub
connects to. The drawback with this solution is that hoping from device
to device is not possible. What are others doing about security?
Bruce Butler, IT Manager
Knappe & Koester
18 Bradco St
Keene, NH 03431
bbutler@...
p.603.355.1166
f. 603.355.2266
Sent: Tuesday, February 08, 2005 8:37 AM
Subject: [Vantage] Digest Number 3173
There are 16 messages in this issue.
Topics in this digest:
1. Re: Wireless for shop
2. RE: Hung job situation
3. Re: Re: Wireless for shop
<cpaluska@...>
4. RE: Wireless for shop
5. Global Customer Setup
6. OT: Exchange 2003 - Multiple Messages
7. Re: OT: Exchange 2003 - Multiple Messages
8. RE: OT: Exchange 2003 - Multiple Messages
9. RE: OT: Exchange 2003 - Multiple Messages
10. Re: Global Customer Setup
11. Progress Programmer / Calvin
12. RE: Progress Programmer / Calvin
13. Crystal Report Distr/DSN Setup
14. RE: Hung job situation
15. RE: Crystal Report Distr/DSN Setup
16. RE: Weird scenario issue
________________________________________________________________________
Message: 1
Date: Mon, 7 Feb 2005 08:40:19 -0500
Subject: Re: Wireless for shop
Charles,
Thanks for the speedy reply.
We are already using terminal server and, I should have mentioned, were
considering using tablet pc's for shipping / receiving / inventory
control functions.
On the subject of cordless phones, there are now several out in the
shop. Many were brought in by supervisors so that the would not have to
trek back to their work center every time the phone rang. These are just
residential units. Are there readily available commercial quality units
that would cause less interference with wireless networks?
Rob.
Knappe & Koester
18 Bradco St
Keene, NH 03431
bbutler@...
p.603.355.1166
f. 603.355.2266
<cpaluska@...>
Message: 1
Charles,
control functions.
Rob.
----- Original Message -----
Date: Sun, 6 Feb 2005 23:00:59 -0500
Put one centrally located access point in each building and you should
be fine. (assuming the interior is reasonably free of obstructions)
However, Vantage will run on the slow side, if it is just for data
collection - it's not too bad, but if you are going to be running any
half way decent reports - it might be an unacceptably long wait. Make
sure to use the 802.11g networking gear - 802.11b is just too slow for
the type of network traffic Vantage generates - especially as you add
more wirelesss nodes.
You can load the Vantage clients locally instead of the default of
running it over the network, but that makes updates a hassle.
If this type of configuration is going to become more the normal mode of
operation - then you need to consider using terminal server or remote
desktop if it is just one or two workstations.
All the other "improvements" can be added later if you need it.
Also, watch out for interference from other wireless networks and
cordless phones. Just because a wireless network is not detected by the
tools in Windows & the software with the wireless adapter - it doesn't
mean they are not there. Good security measures of disabling the SSID
broadcast feature renders the wireless network mostly invisible. The
only way to tell for sure what is running around in your air is with a
spectrum analyzer
Also, the 5Ghz stuff is great because so few people use it and it has 4
times as many non-overlapping channels as the 2.4Ghz technology, but it
has lousy penetrating power and throughput drops off very dramatically
with distance.
Hope this helps - if you have questions please feel free to contact me
off line.
Charles
www.homeplanetnetworks.com
To: <vantage@yahoogroups.com>
Sent: Sunday, February 06, 2005 3:58 PM
Subject: [Vantage] Wireless for shop
> We are considering wireless pc's for some shop applications. Our only
> experience with "wireless" in the shop has been limited to telephones
> and range has been a problem. We have 2 50,000 sq ft buildings that
are
> attached. Their walls are cement block about 12' high on the bottom
and
> then steel the rest of the way up. We have had real problems trying to
> get signals from one building to the other.
> I don't want to run into the same problem with wireless pc's. I was
> wondering what kind of equipment others are using, or have tried.
> Is the a DIY type of thing, or is this a job for the experts?
> * Rob McFarlin, CPA (Inactive)
> Controller
> * Accel Group, Inc.
> 325 Quadral Drive
> Wadsworth, OH 44281
> * Voice: 330-336-0317 x114
> * Fax: 330-336-1224
> * E-mail: RobM@... <mailto:RobM@...>
Message: 2
Date: Mon, 7 Feb 2005 08:43:58 -0500
Subject: RE: Hung job situation
We had this situation of one job hanging....
Seemed our resources were 'stressed'.
We had to turn off ALL of the logs/tracking thru
Business Activity Manager.
Once they were off.. the job was corrected/closed and the logs were
turned on.
BW
Babette Welch
IT Director
Argonics, Inc
1110 Wright Street
Marquette MI 49855
906.226.9747 ext 235
906.228.0951
Sent: Friday, February 04, 2005 9:57 AM
Subject: [Vantage] Hung job situation
We have a bad situation this morning where a job has an operation with a
wildly bad production standard so the estiamted hours is 19,585 when it
should be 1 hour. When either trying to change the standard or siimply
close the job it freezes the user's screen, CPU % for Prowin32 either
maxes
out (close job) or sits at 9-15% (change standard) and freezes or slows
the
user PC. In Promon the user id shows a huge number of record locks
(3,400+). When I kill the user session from Promon I have to do it
twice
(never seen that before). We have tried letting it sit and see if it
will
finish for up to 1/2 hour.
Any suggestions about what may be causing this or how to get around it?
Vantage 6.10.511
Todd Caughey
Harvey Vogel Mfg. Co.
Message: 3
Date: Mon, 7 Feb 2005 09:05:04 -0500
Subject: Re: Re: Wireless for shop
Rob,
Panasonic has several multiline cordless phones that use Frequency
Hopping
Spread Spectrum technology (FHSS). The wireless networking equipment
uses
DSSS (Direct Sequence Spread Spectrum). The FHSS constantly jumps from
one
frequency window to another. It also "smells" the air for other radio
traffic. So the FHSS phones would jump around the DSSS radios thereby
not
causing any interference. The DSSS doesn't move, you pick a channel and
it
sits there.
You could also use 900mhz phones or 5ghz phones without any problems. I
believe a company called enGenius has 900mhz phones designed for the
industrial work place. Another option I'm looking into for a customer
is
using PDA's with WiFi capability and VOIP service. Symbol Technology
used
to have WiFi phone systems, but I just recently checked and they are
discountinued. The Wifi phones would use your existing wireless network
to
communicate back to the phone system interface to gain access to either
the
public or private phone system. The wifi phones are about $200-300
apiece
and the interfaces are over $1000. Because of the costs & maintenance,
paying $15/month for 500 minute Vonage plan per phone isn't a bad deal -
especially since all Vonage to Vonage calls are free.
Needless to say - there are many directions one could take.
Charles
Sent: Monday, February 07, 2005 8:40 AM
Subject: [Vantage] Re: Wireless for shop
> Charles,
were
> control functions.
to
just
units
> Rob.
> From: "Charles Paluska - HPN" <cpaluska@...>
of
the
> spectrum analyzer
4
it
> with distance.
> off line.
> Charles
> From: "Rob McFarlin" <RobM@...>
only
telephones
> are
> and
to
> > Controller
> > * Accel Group, Inc.
> > 325 Quadral Drive
> > Wadsworth, OH 44281
> > * Fax: 330-336-1224
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder
and
> Yahoo! Groups Links
Message: 4
Date: Mon, 7 Feb 2005 07:20:51 -0800
Subject: RE: Wireless for shop
Rob
I have 11 wireless data colletion stations in my two buildings
of
the same size. I mounted two Linksys 54G WAP's in each building(about 15
feet up on poles) for redundency. The only problem I had was when
someone
stole an antenna of a computer. I lock it down by MAC address.
Cliff Drumeller
IT Manager
Mass Precision Sheetmetal
408 954 0200 x 217
_____
Sent: Sunday, February 06, 2005 12:59 PM
and range has been a problem. We have 2 50,000 sq ft buildings that are
attached. Their walls are cement block about 12' high on the bottom and
Controller
* Accel Group, Inc.
325 Quadral Drive
Wadsworth, OH 44281
* Fax: 330-336-1224
have
and
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
Message: 5
Date: Mon, 7 Feb 2005 10:36:54 EST
Subject: Global Customer Setup
Hello,
I am wanting to setup a customer once and let it be used in multiple
companies. There is a checkbox named "Global Customer" but it is grayed
out. Does
anyone know why this would be grayed out? Vantage Help is of no help.
We are on Vantage 6.1 with CRM.
Jeremy
Message: 6
Date: Mon, 7 Feb 2005 09:54:03 -0600
Subject: OT: Exchange 2003 - Multiple Messages
I have an individual that just was built an new XP PC. His old PC was
Win98. He has Office 2000 on his PC. We have Exchange 2003. He now is
receiving messages in in quadruplicate (4 identical messages). Does
anyone know how to stop this? Preliminary searches on the Microsoft
website have not provided any clues.
Juliet Martin
Information Manager
Rosenboom Machine & Tool, Inc.
Sheldon, IA 51201
712-324-4854 x1217
Message: 7
Date: Mon, 07 Feb 2005 16:10:16 -0000
Subject: Re: OT: Exchange 2003 - Multiple Messages
I have something similiar with one user
When you send him a message with a read receipt
You get back two read recipts
Weird
was Win98. He has Office 2000 on his PC. We have Exchange 2003. He
now is receiving messages in in quadruplicate (4 identical messages).
Does anyone know how to stop this? Preliminary searches on the
Microsoft website have not provided any clues.
> Thanks
> Juliet Martin
> Information Manager
> Sheldon, IA 51201
> 712-324-4854 x1217
Message: 8
Date: Mon, 7 Feb 2005 11:06:39 -0600
Subject: RE: OT: Exchange 2003 - Multiple Messages
Have you tried removing this user's exchange attributes and then adding
them again? You could blow away the users mailbox and recreate it.
Mark Smith
Director of Information Systems
Innerpac, Inc
(p) 708-863-8300
(f) 708-863-9770
Sent: Monday, February 07, 2005 9:54 AM
Subject: [Vantage] OT: Exchange 2003 - Multiple Messages
Juliet Martin
Information Manager
Sheldon, IA 51201
712-324-4854 x1217
Yahoo! Groups Links
Service <http://docs.yahoo.com/info/terms/> .
Message: 9
Date: Mon, 7 Feb 2005 11:11:09 -0600
After further investigation it doubled up on his old messages and
current calendar events. It seems to be isolated. I remember this
happening before to a person and it never happened again. I think I
will do what you suggest if it happens to him again.
Thanks for your help
Juliet
Sent: Monday, February 07, 2005 11:07 AM
Subject: RE: [Vantage] OT: Exchange 2003 - Multiple Messages
Mark Smith
Innerpac, Inc
(p) 708-863-8300
(f) 708-863-9770
Juliet Martin
Information Manager
Sheldon, IA 51201
712-324-4854 x1217
Yahoo! Groups Links
Yahoo! Groups Links
Message: 10
Date: Mon, 7 Feb 2005 12:17:03 -0800
Subject: Re: Global Customer Setup
Go to Vantage Help. Search: global customer. Click on Multi-Company
Setup.
See text below "Global Information".
Sent: Monday, February 07, 2005 7:36 AM
Subject: [Vantage] Global Customer Setup
> Hello,
grayed
out. Does
> Thanks
> Jeremy
and
> Yahoo! Groups Links
Message: 11
Date: Mon, 7 Feb 2005 14:53:37 -0600
Subject: Progress Programmer / Calvin
Does anyone know what has become of Calvin? I have been emailing him
and
leaving him messages for weeks with no reply. He was to do some
programming
for us and we need it done. Is there anyone else out there who would be
interested in doing some programming. We are also looking for anyone
using
the enhanced EDI module to help and answer questions about it.
Colette Nunn
Director of Computer Services
East Moline Metal Products
1201 7th Street
East Moline, IL 61265
Phone: 309-752-1381
Fax: 309-752-1382
E-mail: cnunn@...
Message: 12
Date: Mon, 7 Feb 2005 15:58:05 -0500
Subject: RE: Progress Programmer / Calvin
Hi Colette,
We do EDI.
I am not sure what the advanced module is but I wrote our own overlay
converter. We do not have many EDI customers.
We do the 830 schedule, 862 schedule, 810 invoice and the 856 advanced
ship notice.
Give me an idea of what you are looking for.
John Mansfield
General Sheet Metal
Sent: Monday, February 07, 2005 3:54 PM
To: Vantage
Subject: [Vantage] Progress Programmer / Calvin
and
programming
using
Colette Nunn
1201 7th Street
Phone: 309-752-1381
Fax: 309-752-1382
E-mail: cnunn@...
Yahoo! Groups Links
Message: 13
Date: Mon, 07 Feb 2005 21:04:23 -0000
Subject: Crystal Report Distr/DSN Setup
We are trying to create a DSN for Vantage on a Windows NT 4.0 client
that we wish to distribute Crystal Reports to and are getting the
following message from ODBC Administrator: "The setup routines for
the MERANT 3.60 32-Bit Progress SQL92 V9.1D ODBC driver could not be
accessed. Please reinstall the driver". A follow-up message
says: "The setup routines for the %s ODBC driver could not be
accessed. Please reinstall the driver". Any ideas? The PC has the
Vantage client installed and the file PGPRO915.DLL is present in the
C:\WINNT\system32 folder. We are on Vantage 6.1. Thank you in advance
for any and all help!
Sincerely,
Peter Dunbar
Halm Industries Co., Inc.
Message: 14
Date: Mon, 7 Feb 2005 13:13:05 -0800
Todd,
I've had this happen before. It's not locked up. It just may actually
take
2-3 hours or more to process. Just start it on a (fast) PC that can sit
for
a few hours and let it finish.
It happened to us when someone keyed the Job number into a quantity
field
(ouch!). If I remember right, it took ~4 hours to process a simple
quantity
change.
Good Luck!
Pete Wutzke
Giddens Industries
>Message: 5
> Date: Mon, 7 Feb 2005 03:46:11 -0500
> From: "Shirley Graver" <shirleyg@...>
>Todd,
> Check to see if your factory lot size has an appropriate
number
>in it.
>Shirley
> _____
>From: Todd Caughey [mailto:caugheyt@...]
a
maxes
the
twice
will
>Vantage 6.10.511
>Thanks,
>Todd Caughey
Message: 15
Date: Mon, 7 Feb 2005 14:20:01 -0700
Subject: RE: Crystal Report Distr/DSN Setup
Peter,
1 of 2 things is in error:
1. Access rights on the registry key for the ODBC driver are not
correct. The user needs to have rights to this registry key:
H_KEY_LOCAL_MACHINE\SOFTWARE\ODBC\Progress91D
2. The drive that was used to install the network version of
progress is not mapped or the user does not have access to this drive.
These are 2 common problems that will give you error messages with the
ODBC driver from Merant.
Hope this helps; feel free to contact me if you need additional help.
Brandon R Murch
Supervisor of Information Technology
WindStone Medical Packaging
406.259.6387
bmurch@... <mailto:bmurch@...>
Sent: Monday, February 07, 2005 2:04 PM
Subject: [Vantage] Crystal Report Distr/DSN Setup
Sincerely,
Peter Dunbar
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129ecvh0k/M=298184.6018725.7038619.3001176/
D=groups/S=1705007183:HM/EXP=1107896668/A=2532114/R=2/SIG=12k77g7ml/*htt
p:/clk.atdmt.com/NFX/go/yhxxxnfx0020000014nfx/direct/01/&time=1107810268
492465>
<http://view.atdmt.com/NFX/view/yhxxxnfx0020000014nfx/direct/01/&time=11
07810268492465>
<http://us.adserver.yahoo.com/l?M=298184.6018725.7038619.3001176/D=group
s/S=:HM/A=2532114/rand=454016369>
_____
Yahoo! Groups Links
Message: 16
Date: Thu, 3 Feb 2005 09:56:38 -0600
Subject: RE: Weird scenario issue
Jasper, can you set up the customer part in your system and set that #
as a substitute part for yours in the master?
Michelle Von Bokern
Office Manager
Advance Engineering Co.
PH: 630-628-3445
FAX: 630-628-3449
mvonbokern@...
Sent: Thursday, February 03, 2005 9:49 AM
To: Vantage Groups (E-mail)
Subject: [Vantage] Weird scenario issue
Does anybody know if Vantage has a way to handle this scenario or if
there is an easy workaround to this.
We have a part that we purchase. It is a material for an assembly. We
also sell this part directly to our customers as a spare part without us
doing any sort of machining on the part. The issue we have is that we
do not want our customer to know what our part number is for this part.
When they order the part from us as a spare, they as for a different
part number which we call the customer part number. Both part numbers
our in our system.
My question is, is there a way that we can take our part number and
change it to the customer part number without creating a job? We would
need the cost of the part to transfer over also?
OR
Is there a way we can create a shipper for our part number so we can
properly decrease our inventory levels BUT have the customer number
print out on the shipper? The invoice would also have to reflect the
customer part number and not our part number.
Any ideas?
Jasper
Yahoo! Groups Links
Yahoo! Groups Links
