Thanks everybody for the info on the switches. Got a better picture of how
I stand on this now. -Gary
Sent: Monday, March 11, 2002 11:19 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] OT: Vantage and Switches
good thing I deleted Outlook's "adult" filter....
Sent: Monday, March 11, 2002 11:17 AM
Gary,
I have four of these switches. The best way to connect the others is to but
the fiber interface kit or even go with the gigabit interface.
Mine are all hooker together between buildings with 100mb fiber.
Dave
Sent: Friday, March 08, 2002 12:09 PM
Thanks Rick. Great info. I'll see what that does when get some time to
look at the switch documentation. We have two 24-port 3Com 3300
auto-sensing 10/100 switches, linked together as one 48-port module via
their proprietary cable. When I bought the third 3300 24-port switch, it
would have cost significantly more to link this in with the others the same
way. So I just plugged it in to the other switch using a crossover cable -
port-to-port. The network does seem like it could use some performance
help. So that may be the problem. Thanks again.
Gary
Sent: Friday, March 08, 2002 11:02 AM
Gary,
If you have two switches plugged together and both are auto-sensing 10/100,
what they try to do is negotiate the best speed - that being 10mpbs full or
half-duplex or 100mbps full or half. Sometimes switches are known to
negotiate themselves down to 10mbps at half-duplex. If the "master" hub is
manageable, you can set the speed of each individual port - ie if you have a
10/100 hub or switch connected to that port, then set it to 100mpbs only so
it won't go lower.
Rick
<http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=210675.1921839.3417173.1261774/D=egroupweb/S=17050071
83:HM/A=995535/R=0/*https:/www.consumerinfo.com/cb/yahooccms/form_online_a1.
asp?sc=1485REC3> Click Here!
<http://us.adserver.yahoo.com/l?M=210675.1921839.3417173.1261774/D=egroupmai
l/S=1705007183:HM/A=995535/rand=890530235>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
Gary,
Dave
Gary
Gary,
it won't go lower.
Rick
>-----Original Message-----Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
>From: Gary Polvinale [mailto:garyp@...]
>Sent: Friday, March 08, 2002 10:07 AM
>"Do you have other switches plugged into the new 100MHz
>switch? this can
>also
>cause problems." - David, what did you mean, whey you said this?
>Gary Polvinale
>Denton ATD
ADVERTISEMENT
