OT - Networking issue; can't ping server from different subnet
First of all can anything else ping the NAS? I'll assume they can.
Have you checked the laptops hosts file? LMHosts?
Do you use wins?
Have you tried a tracert from the laptop to the NAS? Results?
Have you tried any other devices over the wireless?
Have you tried to connect the laptop to the wired network and ping the NAS?
If none of the above lead to any new clues then I would look for a rogue device, unfortunately 192.168.0.x and 192.168.1.x are the default IP subnets used by most hardware.
Jim
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Norman Hutchins
Sent: Thursday, August 29, 2013 12:45 PM
To: Epicor9 Discussion List; Vantage Yahoo Group
Subject: [Vantage] OT - Networking issue; can't ping server from different subnet
oooooh IT gods...
I'm wondering if anyone out there might be able to help me with an issue
that I'm having with one server and our plant wireless? I've had both Dell
(server; NX400) and SonicWall (Firewall & Wireless) troubleshooting it, for
about 2 weeks, but they haven't had any luck and are sort of pointing
fingers at each other....
Here's a 'brief' synopsis.
*THE PROBLEM*
- Main wired network is 192.168.0.x, DHCP through the SonicWall
- Wireless network is 192.168.2.x, DHCP through the SonicWall
- Laptop connected to the wireless network (192.168.2.106), can ping
4 out of 5 servers on the wired network. Cannot ping our NAS
(192.168.0.250), running Windows Storage Server 2008 R2. One of
the other
server is also running 2008 R2, which is pingable.
- NAS can ping the Laptop
*WHAT WE HAVE TRIED*
- Turned off the Windows Firewall
- Uninstalled the A/V software
- Turned off the teamed NIC
- Booted in Safe Mode with Networking
- SonicWall double checked settings, check and the laptop is sending
out requests, but NSA isn't responding.
- Installed wireshark on NSA, can't see any traffic/ping requests
from laptop.
Any thoughts, ideas, pointers, questions, etc. would be wonderful!
Frustrated IT guy....
Norman Hutchins
System Administrator
Howell Laboratories, Inc.
This email was sent by Howell Laboratories, Inc. or Shively Labs. It may contain information that is confidential or privileged. If you suspect you were not intended to receive it, please delete it without copying or forwarding it, and notify the sender by reply email or by calling 207-647-3327.
oooooh IT gods...
*THE PROBLEM*
the other
from laptop.
Norman Hutchins
Are they using the same gateway?  --- In vantage@yahoogroups.com, <nhutchins@...> wrote: oooooh IT gods...
*THE PROBLEM*
the other
from laptop.
Norman Hutchins
 Are they using the same gateway? (I don't know if this was sent before. The new layout didn't indicate so. --- In vantage@yahoogroups.com, <nhutchins@...> wrote: oooooh IT gods...
*THE PROBLEM*
the other
from laptop.
Norman Hutchins
