Try the web site. I found the following about the cables.
How do I uplink to another hub / switch
You can always connect an ethernet hub/switch to another hub/switch. Some
hubs/switches have uplink ports, and others do not. The configuration for
all scenarios is listed below: NORMAL PORT TO NORMAL PORT ---- CROSSOVER
CABLE UPLINK PORT TO UPLINK PORT ---- CROSSOVER CABLE UPLINK PORT TO
NORMAL PORT ---- STRAIGHT THROUGH/PATCH CABLE NORMAL PORT TO UPLINK
PORT ---- STRAIGHT THROUGH/PATCH CABLE Remember, if you have a link light
than the cable is right. Top of Form 1 Bottom of Form 1
Mitchell Kirby
V. P. Manufacturing
Riten Industries, Inc.
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
Mitchell Kirby
V. P. Manufacturing
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
