Y’all
Wow.
From our case:
This case is connected to an Open Problem [PRB0276185]
ERPS-242738 has been issued for this problem and accepted by Development. It is currently being tested by Development. It is scheduled for Kinetic 2024.1 and will be retrofitted to Kinetic 2023.1.23.
Further developments will be tracked through the above number. Article KB0106088, attached to the case, gives instructions on how to do this. Once this case is closed, you can login to EpicCare and track this number through “My Open Problems.”
I will mark this case as suggested resolution for now. It will close in a few weeks. If you have further questions on this case, please update this case.
