Off Topic - Networking
None at all but I did not start measuring web performance until we got the
T1 line (from a 56K dial service) and implemented the firewall at the same
time. The SonicWall Pro we have allows the dedicated processor to handle
NAT rather than a software implementation on the server so my gut feeling is
performance is not an issue. It has all worked very transparently. I
implemented a SonicWall SOHO2 at home on cable modem and saw no performance
hit there. I did see a total stop to warnings from Norton Internet Security
(software firewall) at home because the SOHO2 box was catching everything
and I also perceived a slight improvement on my main home PC when I
discontinued Internet Connection Sharing which is a software NAT/DHCP
solution.
-Todd C.
Sent: Friday, May 04, 2001 1:57 PM
To: vantage@yahoogroups.com; vantage@yahoogroups.com
Subject: Re:RE: [Vantage] Off Topic - Networking
Todd,
Do you notice any type of performance hit using NAT?
Mike Lowe
Connor
____________________Reply Separator____________________
Subject: RE: [Vantage] Off Topic - Networking
Author: <vantage@yahoogroups.com>
Date: 5/4/2001 1:51 PM
I tried this and gave up. Now using NAT behind a firewall. Also saved a
bit of cost on assigned IP addresses by having only 5 instead of 64. Not
enough to pay for firewall but the extra security is very nice. Not using
DHCP either, just assigned each PC an IP in the non-routable 192.168....
range. We'll never run out.
-Todd C.
Harvey Vogel Mfg. Co.
Sent: Friday, May 04, 2001 12:46 PM
To: Vantage Listserv (E-mail)
Subject: [Vantage] Off Topic - Networking
Ok all you networking guru's out there, I can use a little help.
I run MS BackOffice 4.5 and tcp/ip (not DHCP) I am at my max of available IP
address's for my network. I got today an addition 32 IP's routed to our
company and cant seem to get it working right. The IP's aren't all 64 in a
row, its 2 different blocks of 32 and the subnet mask (from QWest) is the
same. It works enough to log into the network, but something isn't right.
I am unable to ping the gateway and unable to get out on the internet on
these new IP's. I can do all the networking I want within the company but
cant reach the gateway to get out onto the internet.
Any suggestions??? Thanks in advance
Jim MacMillan
Scientific Dimensions Inc
System Administrator
800-523-6180 x 207
jimmac@...
Yahoo! Groups Sponsor
http://rd.yahoo.com/M=163361.1327343.2917869.2/D=egroupmail/S=1700007183:N/
<http://rd.yahoo.com/M=163361.1327343.2917869.2/D=egroupmail/S=1700007183:N/
A=645630/* http://www.match.com/quicksearch/qsearch.htm?AssociateID=226805
<http://www.match.com/quicksearch/qsearch.htm?AssociateID=226805> >
http://us.adserver.yahoo.com/l?M=163361.1327343.2917869.2/D=egroupmail/S=17
<http://us.adserver.yahoo.com/l?M=163361.1327343.2917869.2/D=egroupmail/S=17
00007183:N/A=645630/rand=579108319>
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> > Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Service.
Crystal
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already
<http://rd.yahoo.com/M=190462.1393721.2979173.2/D=egroupmail/S=1700007183:N/
A=551015/?http://www.debticated.com> www.debticated.com
<http://us.adserver.yahoo.com/l?M=190462.1393721.2979173.2/D=egroupmail/S=17
00007183:N/A=551015/rand=984659610>
<http://docs.yahoo.com/info/terms/> Service.
Todd,
Mike Lowe
Connor
-Todd C.
Jim MacMillan
800-523-6180 x 207
jimmac@...
A=645630/*http://www.match.com/quicksearch/qsearch.htm?AssociateID=226805>
To access the Files Section of our Yahoo!Group for Report Builder and Crystal
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
It has zero affect on internal LAN performance. And little or none on
Internet connectivity.
Our NATed Internet connection is through freebie-unix on an old clunker
pentium-100 PC, and I've never seen its CPU use beyond the single-digit
percents, even with the 410K bandwidth maxed out. Which sorta implies it's
fairly low overhead.
-Wayne Cox (really bored and waiting to head out to office going-away
party)
