I was actually looking into subreport but am fuzzy on how they work.
I created a report and called it ServCall_Labor.
On the main report ServCall, I added a line in the matrix and added a blank subreport to it.
I am unsure what to add as the parameters to send to the subreport. I would like to pull all the lines for the JobMtl table first to make sure it works, then use visibility to hide the unnecessary lines.
new subreport
I’ll see if I can come up an example tomorrow - or might be some existing threads here.
In the meantime…
I might try attacking via an existing subreport - “ServCall_Materials.RDL”
Since it’s the one that uses that JobMtl table.
If you can get DocUnitPrice added - then you may be able to built a calculated field(s) for display in the parent report.
Ref screen shot for ServCal_Materials.RDL
steps to add DocUnitPrice would be similar to those in the thread I referenced earlier
Can you mock the desired view up in a BAQ - using the same tables from the RDD?
FSCalHd, FSCallDt, JobMtl, etc…
When I have something a little unusual like this, I find that a BAQ can be the easiest way to identify which tables, joins, groupings, calc fields I’ll need for the report. Once I know that, (I think) it gets easier to weave everything back into the SSRS report.
I had some time to look this afternoon but…
Since I don’t have access to a system with SC Tickets, I found myself guessing at table joins. (Which I still think is the first thing needed before doing too much with the report itself).
So no answer for you but…
Here is a zip with some of my notes & a few example BAQs & maybe something included in it will help. SCTicketReportNotes.zip (753.1 KB)
