<div id="ygrps-yiv-1387325352yiv7882591749ygrp-text">
<div>Hi Ned,<br clear="none"><br clear="none">I value your advice as in the past it's been incredibly helpful, and your post below on E10 has intrigued me.<br clear="none"><br clear="none">We all know that first iterations of major applications can have their quirks, however from what I've been made aware of E10 straight out of the box should in theory be more reliable than probably the latest version of E9 due to extensive testing (much more that Epicor usually do). Do you personally feel that with what you've seen so far this is not the case ? (am I right in thinking that the first service pack for it is due early autumn 2014, so September / October ?). I'm aware of the fundamental changes ('the whole setup'), I've seen the management tools and client, but overall I'd have to say that this is a huge step in the right direction (the native Windows 8 / metro client is a bit ugly !).<br clear="none"><br clear="none">Your comment about Crystal
Reports is also very interesting, it's obvious that at some point in the future Crystal will be totally dropped for SSRS, however I've been told that Crystal is still an integral part of E10. You state… 'it just won’t be worked into the Epicor software as a built in component' … but to me it's been implied that Crystal is still a valid option for all native reports, is this not the case ?.
Thanks.
—In vantage@yahoogroups.com, <TechnoBabbly@…> wrote :
of moving to E10 ASAP is not a good plan for them, or anyone really, you need to do a lot of testing from what I have seen so far, and the whole setup is completely different. I would be skeptical of moving to E10 full production before the major kinks are worked out. Set it up in a test environment and work on the process of updating, and learn how it works, but I wouldn’t start actively working on implementing for a realistic go live it til sometime mid January with a go live around this time of the year.
use crystal, it just won’t be worked into the Epicor software as a built in component, it would be something outside, much like if you are using something like Excel now to build reports.
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mkp #ygrps-yiv-1387325352yiv7882591749hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mkp #ygrps-yiv-1387325352yiv7882591749ads {
margin-bottom:10px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mkp .ygrps-yiv-1387325352yiv7882591749ad {
padding:0 0;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mkp .ygrps-yiv-1387325352yiv7882591749ad p {
margin:0;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mkp .ygrps-yiv-1387325352yiv7882591749ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-sponsor #ygrps-yiv-1387325352yiv7882591749ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-sponsor #ygrps-yiv-1387325352yiv7882591749ygrp-lc #ygrps-yiv-1387325352yiv7882591749hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-sponsor #ygrps-yiv-1387325352yiv7882591749ygrp-lc .ygrps-yiv-1387325352yiv7882591749ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749activity span {
font-weight:700;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749activity span span {
color:#ff7900;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749activity span .ygrps-yiv-1387325352yiv7882591749underline {
text-decoration:underline;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 .ygrps-yiv-1387325352yiv7882591749attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 .ygrps-yiv-1387325352yiv7882591749attach div a {
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 .ygrps-yiv-1387325352yiv7882591749attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 .ygrps-yiv-1387325352yiv7882591749attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 .ygrps-yiv-1387325352yiv7882591749attach label a {
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 .ygrps-yiv-1387325352yiv7882591749bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 .ygrps-yiv-1387325352yiv7882591749bold a {
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 dd.ygrps-yiv-1387325352yiv7882591749last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 dd.ygrps-yiv-1387325352yiv7882591749last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 dd.ygrps-yiv-1387325352yiv7882591749last p span.ygrps-yiv-1387325352yiv7882591749yshortcuts {
margin-right:0;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div.ygrps-yiv-1387325352yiv7882591749attach-table div div a {
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div.ygrps-yiv-1387325352yiv7882591749attach-table {
width:400px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div.ygrps-yiv-1387325352yiv7882591749file-title a, #ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div.ygrps-yiv-1387325352yiv7882591749file-title a:active, #ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div.ygrps-yiv-1387325352yiv7882591749file-title a:hover, #ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div.ygrps-yiv-1387325352yiv7882591749file-title a:visited {
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div.ygrps-yiv-1387325352yiv7882591749photo-title a, #ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div.ygrps-yiv-1387325352yiv7882591749photo-title a:active, #ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div.ygrps-yiv-1387325352yiv7882591749photo-title a:hover, #ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div.ygrps-yiv-1387325352yiv7882591749photo-title a:visited {
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 div#ygrps-yiv-1387325352yiv7882591749ygrp-mlmsg #ygrps-yiv-1387325352yiv7882591749ygrp-msg p a span.ygrps-yiv-1387325352yiv7882591749yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 .ygrps-yiv-1387325352yiv7882591749green {
color:#628c2a;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 .ygrps-yiv-1387325352yiv7882591749MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 o {
font-size:0;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749photos div {
float:left;width:72px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749reco-category {
font-size:77%;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749reco-desc {
font-size:77%;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 .ygrps-yiv-1387325352yiv7882591749replbq {
margin:4px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mlmsg select, #ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 input, #ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mlmsg pre, #ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 code {
font:115% monospace;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-mlmsg #ygrps-yiv-1387325352yiv7882591749logo {
padding-bottom:10px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-msg p#ygrps-yiv-1387325352yiv7882591749attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-reco #ygrps-yiv-1387325352yiv7882591749reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-sponsor #ygrps-yiv-1387325352yiv7882591749ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-sponsor #ygrps-yiv-1387325352yiv7882591749ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-sponsor #ygrps-yiv-1387325352yiv7882591749ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1387325352 #ygrps-yiv-1387325352yiv7882591749 #ygrps-yiv-1387325352yiv7882591749ygrp-vital ul li:last-child {
border-right:none !important;}
