Container
A container is a control that groups other controls together.
This is one of the few controls that can exist outside of a column control. Most other controls need to be placed within a column control.
Property Group | Property | Description |
Basic | Id | Unique identifier for the control |
Basic | Label Text | Sets the label text within the control. (Fig. A) |
Comments | Comments | Add some developer notes to the control. These are not customer-facing and are only visible in App Studio (Fig. B) |
Data | Key Field | Indicates that a bound component is a key field. If true, the field is enabled if there is no current record, allowing the user to select an existing record or create a new one. Not relevant to this component |
Layout | Minimum Width | Setting this allows 2 or more containers to “flex” their size and show up side-by-side if the space is available. (Fig. C) |
Layout | Flex Direction | This defines the direction the controls (that can flex with a min width property themselves) within the container can flex. Values include Row (horizontal), Column (vertical), and Default (horizontal). (Fig. D) |
Layout | Align Main Axis | No idea what this does. I would assume this is suppose to align them on the horizontal axis, but it does not do anythign. |
Layout | Align Cross Axis | This aligns the controls on the vertical axis if the Flex Direction is “column”. If it’s set to “Row”, it just slightly shrinks the control. #Shrug. Valid options include Start, Center, and End. (Fig. E) |
Layout | Gap | Where you buy clothes? I have no idea. This doesn’t seem to do anything. |
State | Personalizable | If true, a user can personalize this component(hide/show) |
State | Customizable | If true, a user can customize this component in child layers |
Figure A: Label Text
Figure B: Comments
Figure C: Minimum Width
Figure D: Flex Direction
Figure E: Align Cross Axis
