I create a extended table: JobHead_UD
The table and data model are in sync
I go into Job Entry, created a new sheet and added some text fields which I want to set to fields in the new JobHead_UD table.
Add the textbox, and go to: EpiBinding…
and the JobHead_UD table is not available to select.
I manually typed in the name of the field: JobHead_UD.Serial_c and when I go to launch the form with the customization I get an error:
Control ‘epitxtSerial’ of type EpiTextBox has an invalid binding to view JobHead_UD.
What else do I need to do to use these UD fields on a form customization?
